2nd high wing
what would be a good 2nd plane high wing rtf or a easy kit that you just add engine and receiver got a good deal on a .52 evolution today i would like something that is easy to fly and will do more than the nexstar i have now
RE: 2nd high wing
If they still make them get a Midwest Aero Star with a fully semetrical wing. I got one off of Ebay for $125 shipped.
RE: 2nd high wing
Its called the Midwest Aerobat.
RE: 2nd high wing
Hangar 9 Arrow.....with that 52 it will amaze you
RE: 2nd high wing
OK one more for ya.
http://www.rcuniverse.com/product_gu...fm?kit_id=2569 |
RE: 2nd high wing
goldberg falcon 3 has a semi semetrical wing. there are also a few good other high wing with semetrical or semi semetrical wings. look at the specs. the semi semetrical will be a little faster than the trainer flat bottom wing. the full semetrical will be a hand full.
RE: 2nd high wing
1 Attachment(s)
ORIGINAL: joco1 what would be a good 2nd plane high wing rtf or a easy kit that you just add engine and receiver got a good deal on a .52 evolution today i would like something that is easy to fly and will do more than the nexstar i have now The Kyosho Calmato high wing comes with surfaces hinged and hinges glued. Horns installed. Motor mount installed. One of the most ARF models you'll ever see. Better than a few RTFs almost. ;) Unfortunately, you do need to run an iron over all it's seams first and then everywhere else. But that's easy and especially if you do it first thing. It's a good light 46size. And flies very nicely. And will do everything you'll want to do with your 2nd airplane. The one in the picture was done last year. Behind it is a Tiger that was shelved for a Calmato Sport low wing that flew slightly better. |
RE: 2nd high wing
You might consider an Avistar. Semisym wing and with a 46 up front will do all the basic aerobatics.
RE: 2nd high wing
World Models Mach I Skyraider, semi sym. wing, will do some aerobatics. Built well with surfaces already hinged and good wood.
$79.99, goes together in a flash..... http://www.airborne-models.com/html/...p?ProductID=15 Ronnie-The Toolman :D |
RE: 2nd high wing
I'll second the Sky Raider Mk I - good flying plane that will be able to perform all the aerobatics you'll want to fly for a while, and with the throws reduced makes a gentle flyer - it's a great second plane.
Hogflyer |
RE: 2nd high wing
Why not a stick? Big Stik, Super Stick, Ultra Stick, (Fill-n-the-blank) stick??? It was said to me "....Nothing Flies Like A Stick...." Believe me, my Big Stick is AWESOME!!
RE: 2nd high wing
the guy at the kyosho seemed unsure if the .52 engine would be too much what do you think
RE: 2nd high wing
The .52 will work fine in the Mach I
Ronnie |
RE: 2nd high wing
+1 on the Sky Raider. A very well-engineered plane, goes together in a few hours and you can't beat the price.
Copyright © 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
