RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Possible? (https://www.rcuniverse.com/forum/beginners-85/6444330-possible.html)
Electrolight 10-03-2007 10:46 AM
Possible?
Could I add floats to a MK II 40 Towwer Hobbies Trainer w a .40 super tigre engine?
Electrolight
ro347 10-03-2007 10:54 AM
RE: Possible?
I would go with the Super Tiger 45. Planes that Ive seen with a .40 on them seem pretty underpowered. All trainers.
TideFlyer 10-03-2007 01:19 PM
RE: Possible?
Might be tough getting a 40 trainer up off the water with a .40. A .46? Different story.
bjb6723 10-05-2007 01:49 PM
RE: Possible?
My Tower 40 trainer has a GMS .46 on it. It flies ALOT better than with the .40 I used to have.
acarter 10-05-2007 02:23 PM
RE: Possible?
yea, why not get a cheap OS .46 la i think they are like 65 at tower hobbies, then you can either sell the 40, save it, or use it for another plane
Ausitn
acarter 10-05-2007 02:25 PM
RE: Possible?
oh yea, there is a [link=http://www.rcuniverse.com/forum/forumid_176/tt.htm]seaplanes[/link] forum her on RCU
Austin
MinnFlyer 10-05-2007 02:38 PM
RE: Possible?
Rather than get another "Cheap" engine, spend a few more bucks and get a Ball Bearing 46
The Evolution 46 or the Thunder Tiger 46 Pro can be had for around $80
RICMOD5634 10-05-2007 07:40 PM
RE: Possible?
If it is set up right, it should fly it, although slow. Forget the OS 46LA, the Super Tiger 40 will have more power. If you want to go with a better engine, go OS 46AX.
ro347 10-05-2007 08:51 PM
RE: Possible?
The ST 45 is comparable if not more powerful than the OS 46AX and cheaper too. I have both.
Electrolight 10-05-2007 09:21 PM
RE: Possible?
Ok thanks guys I think I may buy an OS 46AX or the ST 45. This was a question for future experimentation.
Electrolight
FLYBOY 10-05-2007 10:21 PM
RE: Possible?
ditto, a good .46 would be good. You will have fun.
OzMo 10-05-2007 10:54 PM
RE: Possible?
I had an Eagle II by Goldberg with floats and the os 40 abc FSR. no problem at all on the water. super tiger 40 well tuned and a well set up plane and floats keep it light and I mean LIGHT;):D you should be fine. but then I fly an os 46 on my trainer ( LT40) now:)
