.25 trainer arf
can anyone recommend an arf .25 trainer?
RE: .25 trainer arf
Here are good trainer kits in that size, couldn't find an ARF that size. Most ARF glow trainers seem to be 40 size and larger.
Sig Kadet LT-25 Sig Kadet Seniorita Hobbico Sturdy Birdy II w/Ailerons Great Planes PT-20 MkII Goldberg Eaglet 50 Goldberg Freedom 20 |
RE: .25 trainer arf
There had been one in the RCU market place but it seems to be gone now. Just keep an eye on the market place they pop up about once a month or so. The other option of course is to build one of the above mentioned kits.
Nice avitar by the way:D |
RE: .25 trainer arf
Here's the only ARF I've seen:
http://www2.towerhobbies.com/cgi-bin...?&I=LXEDN6&P=0 They have a low wing trainer as well (for a 2nd plane): http://www2.towerhobbies.com/cgi-bin...?&I=LXEDN7&P=0 |
RE: .25 trainer arf
1 Attachment(s)
I have and fly both the High and Low Wing Sonics by Phoenix. They are both excellent flyers ! I have a GMS .25 in the Low Wing and a GMS .32 in the High Wing. they are a BALL ! The High Wing will make an excellent Trainer with a .25. The Low Wing is a little more "Sporty" !
Ugo |
RE: .25 trainer arf
Do you have standard size servos in them?
RE: .25 trainer arf
Is there a reason for going a .25 size ? If you go to a .40 size trainer, you have a lot more to choose from. You can also fit it with a big enough engine, for you next plane. Like a .46 or so.
RE: .25 trainer arf
Yes I do ! All Hitec 311's @ $8.99 ea, !
Ugo |
RE: .25 trainer arf
ORIGINAL: Insanemoondoggie Is there a reason for going a .25 size ? If you go to a .40 size trainer, you have a lot more to choose from. You can also fit it with a big enough engine, for you next plane. Like a .46 or so. Nice avitar by the way |
| All times are GMT -8. The time now is 10:57 PM. |
