Off topic ?
Where can I get a scroll saw/ sander combo? I know I've seen them, just can'y remember where..
Thanks |
RE: Off topic ?
I have one that is a Dremel that came from the hobby shop
http://www.amazon.com/Dremel-1800-01...2321753&sr=1-1 |
RE: Off topic ?
RE: Off topic ?
just go to lowes or home depot, they have a good selection
RE: Off topic ?
You might want to put Sears in the mix as well. They have a nice selection of saws. Good Luck, Dave
RE: Off topic ?
Just a few commetns about the dremel
School had bought one and its one of the only ones kids havnt destroyed but they have found some weak points, While not a problem if workign alone you cant use the sander and saw at the same time doign both is jsut oo hard on the motor (the problem only happened when one kid was cutting and onther was sanding on the same tool but again i dont think youl be cutting and sanding at the same time so that shouldnt be a concern) Also the blower thing will eventully crack if its played around with alot Other then that a great saw Steven |
RE: Off topic ?
The Dremel is not a commercial - heavy duty saw. It is for home - hobby use.
RE: Off topic ?
This was shop class most of what we did was cutting 1/2 inch pine nothing more then that......
It held up great and if i needed one i would probably get the dremel.... |
RE: Off topic ?
Thanks bunch's..
| All times are GMT -8. The time now is 04:29 PM. |
