RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   How do you work with GP hinge slot machine? (https://www.rcuniverse.com/forum/beginners-85/6606495-how-do-you-work-gp-hinge-slot-machine.html)
Alex7403 11-10-2007 06:41 PM
1 Attachment(s)
Here is my problem:
I’m afraid it wont cut the slots straight = perpendicular and will emerge out, how to make it perfect?
Alex
ChuckW 11-10-2007 06:46 PM
RE: How do you work with GP hinge slot machine?
First off, let the cutter do the work. If you try and force it there is a chance the blade could deflect. GP also sells a guide tool that helps keep it centered and straight. Bottom line is just take your time and make sure everything is straight.
http://www3.towerhobbies.com/cgi-bin...?&I=LXPU13&P=7
Alex7403 11-10-2007 07:30 PM
O.K. its not so hard, I’m practicing it now, just the 40 size ailerons are very thin.
MinnFlyer 11-10-2007 07:55 PM
Practice is a good thing!
The guide the GP sells is a really handy tool, but it will not help you make it go straight in, that's up to you - just like when you cut them by hand
Geardaddys 11-10-2007 08:00 PM
I've found that it works best if you mark where you want the hinge with the tool that was mentioned avove.. then, turn on your slot cutter and place only the left or right "corner" of where the cutting happens into your balsa first, then slide the rest of the blade in carefully..
bruce88123 11-10-2007 09:36 PM
It's also easiest if you cut the slot BEFORE beveling the surface.
Alex7403 11-10-2007 10:16 PM
I was looking for a trick or something.
bruce88123 11-11-2007 08:47 PM
Practice a few times on scrap material. It will help calm the nerves.:D
Alex7403 11-11-2007 09:33 PM
just wanted to avoid the drive to LHS because of ailerons.
