Replacing Push Rods
I'm not real happy with the push rods that came with my ARF. They're wooden dowel w/wire on each end. They're pretty flimsy and appear to be binding when I installed them.
Since I no longer have access to the inside of the fuse, something I need to anchor (like NyRod) is out of the question. What can I use to replace the original pushrods that will be a little less flimsy? Thanks Mark |
RE: Replacing Push Rods
Mark, use carbon fiber push rods, or fiberglass arrow shafts.
Don |
I use the Dave Brown fiberglass pushrod system. It comes with two 36" fiberglass shafts and enough ends to make single or double pushrods.
David |
ORIGINAL: MarkDiDo What can I use to replace the original pushrods that will be a little less flimsy? |
You could also go with a pull-pull system.
And just because its finished, doesn't mean you can't access the inside. I've cut and repaired LOTS of holes to access the inside. Brad |
| All times are GMT -8. The time now is 01:46 AM. |
