RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Bought an Utter Kaos 60 from BlueJay models (https://www.rcuniverse.com/forum/beginners-85/6647062-bought-utter-kaos-60-bluejay-models.html)
iluvflying 11-19-2007 08:24 PM
I was pleased with the balsa and the service from BJ models, however I was shocked a bit to realize that the instruction manual was only text vs a photo illustrated manual that I am using on my 4*60. I could sure use some help from anyone who has buit a Bridi kit from text especially photos of the building process vs completed covered models.
TIA
Philip
w8ye 11-19-2007 08:27 PM
RE: Bought an Utter Kaos 60 from BlueJay models
All the Bridi kits were this way. I suppose BlueJay didn't change anything?
If you've built a few kits, they are straight forward. The bottom of the airfoil is straight from midpoint to trailing edge on the bottom.
There are shims supplied to make the wing straight.
I have the plans copied at the printers and work off the copied prints - saving the originals
You will find a detailed build with hundreds of pictures somewhere on here. I'm thinking kits but it may have been Senior Pattern?
Kaos Rulz 11-20-2007 07:26 AM
YEP! The Bridi kits have always been a "Buildiers" kit, but boy do they fly well!
iluvflying 11-20-2007 09:25 AM
Two things Blue Jay changed from the original are:
1) drilled two holes per rid to allow building on wing jig
2) fuselage is one long solid piece
Happy Thanks Giving to all on RCU :)
Philip
w8ye 11-20-2007 09:52 AM
This should get you going? I see you've already been to some of these?
http://www.rcuniverse.com/forum/m_33...tm.htm#3307045
http://www.rcuniverse.com/forum/m_66...tm.htm#6634085
http://www.rcuniverse.com/forum/m_65...tm.htm#6583400
http://www.rcuniverse.com/forum/m_30.../tm.htm#302131
http://www.rcuniverse.com/forum/m_65...tm.htm#6599239
http://www.rcuniverse.com/forum/m_46...tm.htm#4634432
http://www.rcuniverse.com/forum/m_44...tm.htm#4484604
http://www.rcuniverse.com/forum/m_42...tm.htm#4294936
http://www.rcuniverse.com/forum/m_29...tm.htm#2974995
http://www.rcuniverse.com/forum/m_22...tm.htm#2264811
iluvflying 11-20-2007 04:49 PM
thanks
