engine for ARF
Hello All, I'm thinking of buying a Graupner Piper Cub ARF. The kit calls for a .46 2-stroke, or .72 to .80 4-stroke.
I already have a OS .46 FX. This is supposed to be a fairly robust engine, and I'm just looking for a plane to put it into. Do you think that this is enough engine for the cub? (72" span, 6.5 lbs). I'm not looking to do much in the way of aerobatics, just want to cruise the skies. Thanks! |
engine for ARF
Your 46FX will do great! Just use a larger diameter prop with a flatter pitch. I think an 11X5 or a 12X4 would work great. I also think you should use a wood prop. Wood props are lighter, and a Cub simply must have a wood prop! :D
engine for ARF
GalenB is right on! Your 46 FX will be perfect.
Cub
I have a Saito 80 on mine I love it:)
engine for ARF
Your engine will be fine. Personally, I like the sound of a 4-stroke on something like a Cub. :)
engine for ARF
Originally posted by MinnFlyer Your engine will be fine. Personally, I like the sound of a 4-stroke on something like a Cub. :) Paul |
| All times are GMT -8. The time now is 09:19 AM. |
