Prop size
What size propellers can a hobbyzone super cub take i am currently running stock propellers and dont have accest to any of them same size. So what other size can the super cub run on i have access to most sizes except 10x8.
thanks help will be apreciated |
RE: Prop size
it says to ues a 10x8 but mabey a 10x7 or 10x6 will work
http://secure.hobbyzone.com/catalog/...s/PKZ1005.html |
RE: Prop size
If you go up in lenght 1 size go down in pitch 1. (the opposite also works)
10 / 8 should be swappable with an 11/ 4 or a 9/ 7 roughly. |
RE: Prop size
ORIGINAL: OzMo If you go up in lenght 1 size go down in pitch 1. (the opposite also works) 10 / 8 should be swappable with an 11/ 4 or a 9/ 7 roughly. If you're using a 10X8 now, an 11X6 would be a match as far as load on the motor. A longer prop with a shallow pitch will give you less speed but more thrust. A shorter prop with a steeper pitch will give you less static thrust, but more speed. |
| All times are GMT -8. The time now is 03:08 PM. |
