RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   twist engine mounting? (https://www.rcuniverse.com/forum/beginners-85/6896496-twist-engine-mounting.html)
Bretd123 01-12-2008 06:09 PM
i am trting to mount my o.s. but i think that the bolts are too short. The bolts only come about 1 third of the way into the locknuts. what should i do? Surely Hangar 9 wouldn't give you this bad hardware would they?
w8ye 01-12-2008 06:59 PM
RE: twist engine mounting?
You can get longer bolts at the hardware store or the hobby shop
bruce88123 01-12-2008 08:19 PM
Any chance that you used the correct length bolts somewhere else in the plane by mistake?
richg99 01-12-2008 09:08 PM
Any chance that the blind nuts (assuming that that is the mounting system) haven't been pulled all of the way into the wooden base? I had to draw some in with the bolt and a washer..then back everything out and then mount the engine. Rich
Flying freak 01-12-2008 11:32 PM
ORIGINAL: richg99
I think he is talking about the motor mount to motor connection and not the motor mount/firewall connection
As mentioned above just get longer and keep those somewhere for your next project if you find them too short.;)
Steven
horace315 01-13-2008 12:04 AM
i have to almost always draw my blind nuts in that way put a few drops of ca glue on them afterwards making sure not to get any in the threads.
bruce88123 01-13-2008 01:36 PM
The Twist 40 ARF manual calls for using 3mm socket head screws to mount the engine to the mount. The stated length is 20mm or 0.787 inch (just over 3/4"). Then they call for 3 mm washers & nuts. If this is what you have and it isn't working (for whatever reason) then you need longer screws which should be readliy available at the LHS. 8-32 hardware would do just as well if you have it laying around.
