RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   46fx Sagging in Transition. Thoughts? (https://www.rcuniverse.com/forum/beginners-85/6921383-46fx-sagging-transition-thoughts.html)
TideFlyer 01-17-2008 09:45 AM
At idle, when I apply throttle quickly, the engine sags noticeably. It doesn`t sputter and burble like you ordinarily associate with a rich low end, it justs sags, sometimes to the point of cutting out. I`ve been working from the assumption that it`s loading up at idle because when I run it at open throttle ( runs fine )and cut it back, and then quickly open the throttle again, it transitions fine. Maybe my assumption`s off base (?). I`ve been leaning out the low end, but so far without much improvement ( some though ). Any thoughts would be appreciated. Maybe I just haven`t hit the sweet spot on the low end? Thanks.
w8ye 01-17-2008 10:03 AM
RE: 46fx Sagging in Transition. Thoughts?
What glow plug are you using.
MinnFlyer 01-17-2008 10:03 AM
Maybe you're too lean at the low end?
TideFlyer 01-17-2008 10:09 AM
OS8
da Rock 01-17-2008 10:36 AM
ORIGINAL: TideFlyer
You don't mention using the pinch test. Try it.
With a warmed up engine, set the highspeed needle.
Let it idle awhile. Say 20-30seconds.
Pinch the fuel hose close to the carb. Pinch it completely closed.
It'll take a couple of seconds to run out of fuel, but when it does:
If it speeds up before shutting off the lowspeed needle was too rich and the optimum setting would have been leaner.
If it simply dies, it was probably too lean. It could also have been very close to perfect. Give it a very fine tweak richer and try again.
Pinch test is one of the best tests we got.
Missileman 01-17-2008 11:04 AM
ORIGINAL: da Rock
ORIGINAL: TideFlyer
And it is a good test on both low idle and full throttle settings.
TideFlyer 01-17-2008 11:42 AM
Thanks guys, appreciate it. I`ve used the pinch test on the high end before. I`ll try it down on the low.
