RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   PT40 wing advice (https://www.rcuniverse.com/forum/beginners-85/695562-pt40-wing-advice.html)
WhiteKnuckles 04-14-2003 11:26 PM
PT40 wing advice
Is it possible to follow all the steps for both "rubber band" and "bolt on" wing configurations while building?
I'd like to do both and use the rubber bands to start and change to bolt configuration later.
Or, are the plans set up for one or the other.
bdphil 04-14-2003 11:51 PM
PT40 wing advice
I don't really remember if the plans allow you to convert to bolts at a later time, but I'd suggest going with the bolt on method from the start. Rubber bands are a pain and they mess up the covering after a while.
One other piece of advise, build the "sport" wing with less dihedral. I built one last summer for my dad and I built the "trainer" wing and there is too much dihedral IMO. A 10mph crosswind will blow it right over.
Ben
CafeenMan 04-15-2003 01:12 AM
PT40 wing advice
WhiteKnuckles - The idea that rubber bands will prevent damage in a crash is not true for the most part. If the wing gets twisted the fuselage will be damaged regardless of attachment method.
The real reason to use rubber bands is because many beginning builders have problems drilling the holes for wing bolts accurately. It's hard to go wrong with dowels and rubber bands.
But like bdphil said, they're messy, a continual expense and mess up the covering. Additionally the rubber band mounting method weighs more than using nylon bolts, but the difference is probably only a few grams.
My vote is that if you think you can successfully drill and tap for the bolts then go with that method.
A couple of tips:
1) Before you do anything get the wing on straight and level. Make a couple reference marks on the wing and fuselage.
2) Measure the exact center of the blocks in the fuselage for the bolts. Transfer those marks to the wing. Actually, you want to be centered back and forth, but slightly to the rear of center because of the way the bolts enter the blocks.
3) Drill the wing (3/16" bit for 1/4" bolts) with the drill perpendicular to where the bolt head will contact the wing. That means the bolt will go into the block at an angle.
4) Seek experienced help to step you through it in person before you attempt it on your own.
WhiteKnuckles 04-15-2003 02:37 AM
PT40 wing advice
Thanks guys. This site is incredible. I'm pretty confident of my ability to drill a hole, though I will seek advice first. :) I have been told, without variance, to definitely build the sport wing. I will follow that advice. I like the idea of a trainer, but I live in a very windy city and don't want to limit its lifespan prematurely. Cheers.
CafeenMan 04-15-2003 02:40 AM
PT40 wing advice
Drilling the hole is easy. Getting it in the right place at the correct angle takes some preparation.
Glad you like it here. :thumbup:
MinnFlyer 04-15-2003 12:25 PM
PT40 wing advice
I'm sorry, but I TOTALLY disagree! Rubber bands will prevent a LOT of damage in case of a minor mishap. In the case of a major crash, they won't help any, but if a wingtip is jarred, all of that leverage is transferred to the tie-down point. If it is rubber, it will give. If it is bolts, something else has to give, and guess what it's going to be... You will split your fuselage open like a ripe mellon!
Please, use the rubber bands. You can graduate to bolts on your second or (better yet) your third plane.
WhiteKnuckles 04-15-2003 12:43 PM
PT40 wing advice
Thanks for your advice. It wouldn't be advice if we all thought the same way; it would be common sense. I'm leaning toward the "bolt on" method because I'm pretty much there in terms of the build. I've also got an advantage over some people in the sense that my club is good and I've got lots of people willing to instruct me. I should be able to take it slowly. I'm also thinking of throwing together a "trainer" SPAD and beating it to death. My balsa trainer is something I'd like to have for many years. We'll see. :)
bearmech 04-15-2003 12:44 PM
PT40 wing advice
build the sport wing and use even less dihedril(sp) if your building skills are up to it. use rubber bands as stated in the previous post but go ahead and install the provisions for the bolts now and they can be drilled later. be sure to check the wing incedence (it's not perfict out of the box). I've built 2 PT 40s this year!! one for my son and one for me. rubber bands saved his fuselage in the tall grass. I split my fuselage in a simular situation using bolts.
WhiteKnuckles 04-15-2003 01:00 PM
PT40 wing advice
By "even less dyhedral" do you mean less than the sport wing plans in the manual? I would like a plane that I can fly for a longer period of time and still enjoy, as opposed to one that has a limited lifespan. If that means it's more difficult to learn, so be it. There are guys here who will train me on their PT40s that have tons of dyhedral. As for bands vs. bolts, perhaps I'll go and insert the parts and drill the holes for bands so I can do both. Thanks again to all of you.
WhiteKnuckles 04-15-2003 01:01 PM
PT40 wing advice
And what do you mean by "wing incidence"? I've had a few "incidents" already, none involving the wing. ;)
bearmech 04-15-2003 01:05 PM
PT40 wing advice
Yes less than the sport wing, but not totally flat. It means you have to build new wing joiners or modify the current ones. be sure you carefuly measure your wing root cuts. the washout jigs would need to be shortened a little also.
WhiteKnuckles 04-15-2003 01:08 PM
PT40 wing advice
That's great advice. Thanks. My biggest fear was creating a wing that will either bore me to death or be unacceptable here in Calgary where the winds are very high.
Goinstraightup 04-15-2003 02:21 PM
PT40 wing advice
I'm glad you are building the Sport wing. The other one flys so crummy it is unreal. I spent 6 hours last summer chopping a students wing in half to fix it.
WhiteKnuckles 04-15-2003 04:57 PM
PT40 wing advice
Bearmech, how many inches of dyhedral do you recommend on each side?
Montague 04-15-2003 05:15 PM
PT40 wing advice
Go with rubber bands. They won't help in all mishaps, but it can really help in some accidents. There might be a way to crash that would cause more damage with rubber bands than bolts, but I'm having a hard time thinking up how. Building so you can switch to bolts later makes sense, though.
Also, a note on rubber bands, I think a lot of guys put way too many on the plane, taking a "more is better" approach, and being overly worried about losing the wing in flight. However, putting on too many bands leads to too much pressure on the wing, and reduces the ability of the bands to flex and absorb energy in an accident. For a .40 size trainer, with limited expected acrobatics (just enough acrobatics to avoid the ground when necessary), I'd say no more than 5 or 6 per side.
as a side note, my combat planes use rubber banded wings. I use 4 per side on my 3.5lb .28 powerd B class ships, plus an extra band run accross from font to front and another from rear to rear. The plane is a bit lighter than a trainer, but the G forces in the air are much higher. I've had many head-on wing-to-wing mid-airs, and let me tell you, having the wing move a little can really save your bacon, the energy absorbed can make the difference between landing in 1 peice or several. I've flown out of several mid-airs with the wing visible crooked, but the airplane still very flyable and controlable.
If you are worried about the wing shifting too much, you can borrow another combat trick, put velcro on the wing saddle and wing instead of the foam tape. The velcro gives a little bit, absorbing some energy, but will help keep the wing from coming all the way off.
Goinstraightup 04-15-2003 06:06 PM
PT40 wing advice
I think when I fixed my students we ended up using 1 3/4" total.
bearmech 04-17-2003 02:16 PM
PT40 wing advice
I use 1.5" in the second pt40. seemed to work fine.
TX-Deck 04-17-2003 03:26 PM
How about both?
I'm currently learning to fly on a kit built PT-40, and chose to build the wing with more dihedral.
My plans for when I outgrow that wing setup, is to scratch build a wing with less dihedral, such as the "sport" setup suggests.
Just another option to consider. Cheaper than building a complete new plane, but still fairly involved.
Good luck!
FLYBOY 04-17-2003 03:44 PM
PT40 wing advice
If you go with bolts, use nylon bolts and make sure to use the propper drill before you try to tap it. I have seen many people use a 1/4 inch drill and then the tap just drops right through. Look at the tap and it will tell you which numbered drill to use. Buy that bit. it will make a better hole.
Montague 04-17-2003 06:12 PM
PT40 wing advice
TX, another, cheaper option would be to build a SPAD wing. Maybe build the SPAD wing with the extra dihedral, and the kit wing done flatter. That way, the SPAD wing takes the early abuse and you can save the "pretty" kit wing for later, when you're less likely to break it. (not that SPAD wings can't look nice, they sure can).
WhiteKnuckles 04-27-2003 11:08 PM
SPAD wing
A SPAD wing. I hadn't thought of that. Not only can I sleep easier, but I imagine it would be a faster build time. Which would you recommend, the Spadet maybe?
mtnlvr 01-12-2004 01:51 PM
RE: PT40 wing advice
ORIGINAL: WhiteKnuckles
I'd like to do both and use the rubber bands to start and change to bolt configuration later.....
Did you ever switch over to bolts? If so, how much prep for the bolt sutup did you do during initial building and how much of a struggle was it to switch over? I'm building a PT-40 right now and wondered about doing the same.
phread59 01-12-2004 03:04 PM
Hey MTNLVR, I have the older version of this kit. Bolts were not an option when I built this kit. I do not know how the dowels go in. If they are to go in a bracket that drops below the wing (like the updated version of the RCM advanced trainer that I am building now.) . I would put the brackets in and drill the dowel holes and not install the leading edge dowels. if they are in the wing itself I would build the wing and install the dowels and drill the holes for the bolts. When flying with bands I would say you have to live with the dowels being used. Either way you would install the dowels for the rubber bands. I converted a Kadet SR to bolts. I used the band dowels anyway as reinforcements. Cut them off flush and covered the plane. I hope this helps.
Mark Shuman
mtnlvr 01-12-2004 05:32 PM
phread59....Thanks for the idea. There is a plate that the single L.E. wing dowel goes into. The manual says to only install that plate if opting for the bolt-on wing so I'm not quite sure if it will cause and problem using rubber bands. I'm thinking of drilling the wing and preparing all the other stuff for the bolt-on, but then applying the covering over the dowel hole and the bolt holes in the wing. That way it looks nice and when I want to use bolts I'll just have to trim the holes and glue in a dowel.
I guess I'll see tonite what I decide to do.
phread59 01-14-2004 02:47 PM
If I read your post right the dowells go through the leading edge. If this is so I would definatly install the dowels. The reason being without the dowels you have a hole in the leading edge. This will create a stress point and a corresponding weak point. Just put the dowels in. Yea even though you are using bands the dowels will be engaged. Don't worry about this they will not be holding much. And will make centering the wing easier. The wing will go on straight and consistantly every time. Something that is hard to do with bands. Good luck and I hope you do well. Oh and don't worry about looks. Tey won't look bad. And if someone syas they look goofy who cares! Rule number 1,It's my D**N airplane! LOL
Mark Shuman
mtnlvr 01-14-2004 05:36 PM
phread59.....After reading through the manual (and many posts here), I decided to ditch the bolt-on wings. The dowel for bolt-on wing does protude from the wing's L.E., but it hides behind the windshield. The problem is this; if I installed the reinforcement for the bolt-on wing, it would interfere with the front dowel for rubber-banding the wing.
The other reason though is that I know this things gonna fall from the sky and I want the repairs to be as minimal as possible. Have the invented remote activated airbags for RC planes yet?:)
WhiteKnuckles 03-18-2004 04:53 PM
Just wondering how everyone did with their PT40s? I have been flying mine for the better part of a year. I flew it off skis for the winter and converted it to a tail dragger in January. I've had lots of nose-overs with the trike skis, I had one dead stick crash in which the wing popped off unharmed, but the fuse opened up (no biggie). I've flown it in crazy winds too. All in all, it has been fun. I just put an oversized servo wheel on the ailerons, hoping to increase the roll rate. Immelmans are hilariously slow. I'll post a photo sometime.
mtnlvr 03-18-2004 05:51 PM
My PT turned out great. Very little trimming required. Was ready to fly in February. Ended up putting some skis on it and it seemd to fly good. I had about 4 flights on it up until yesterday where with some moral support from a friend, I got the real first solo out of the way. I flew about three times with him nearby and then I was the only one at the field for the next 3 hours. Made many flights and with no harsh landings I'll have many more to come.
I too had several nose-over landings with my trike setup. It may be because the ground is really soft and actually has up to 2" of settled water.
I'll have to scan a photo when I get one developed or wait til my Mom comes to visit with her digi.
WhiteKnuckles 03-18-2004 08:06 PM
1 Attachment(s)
Here are a couple pics of the PT40, hanging in my garage. Note the tail wheel.
Ashes 04-01-2004 11:34 AM
I am currently getting ready to join the wings on my PT-40. I have built the sport wing but am wondering if it is still too much dihedral?
If I have already cut them to the sport dihedral will making them even less cause any problems as far as taking off too much wood when changing the dihedral? I just do not want to make any mistakes at this point but don't want a wing that I am going to "outgrow" too quickly. Would appreciate any feedback.
mtnlvr 04-01-2004 11:49 AM
ORIGINAL: already cut them to the sport dihedral will making them even less cause any problems
I would recommend taking out more dihedral. I finished my PT with the 'sport' wing in February. As a beginner pilot, I've flown a gallon of fuel through my PT and wish that I would've done the same. I think I would cut the dihedral in half. The flat bottom, top-mounted wing will still be very stable in flight.
As for removing wood, as long as you haven't attached the root rib all you'll do is make the wing a little shorter. No big deal. You may have to shave the wing joiners a little too.
Just keep in mind that the washout jigs will have to be shortened by the same amount as what the revised wing tip drops. You'll have to trig that out.
Goinstraightup 04-01-2004 12:11 PM
I think you'll be fine Ashes. The Sport wing as you have it should work good for you.
Jeff
WhiteKnuckles 04-01-2004 12:58 PM
The sport wing will probably be fine for you. I live in a very windy city, so I took my dihedral down to 3" combined. It works very well and it is still stable. The more the dihedral, the more the plan tries to fly itself. That makes it difficult in high winds.
The wing span is 60 or 61 inches. If you knock it down to 58, I don't think you'll notice a thing. And you won't have to take that much out.
Keep in mind that the PT-40 is a flat-bottom trainer with a non-symetrical wing. It will never go too fast or roll too quickly. That means you'll outgrow the whole plane, not just the wing. On the other hand, you've always got a relaxing, Sunday flier to cruise around with.
I ended up converting mine to a taildragger, decreasing dihedral, and maximizing throws on all control surfaces. She's still a lazy plane. Rolls take forever and Immelman's are hilariously slow. It's a fun way to get going.
Ashes 04-02-2004 08:53 AM
Thanks for the input guys. Joined the wing last night and will continue on with the sheeting tonight and hopefully get it covered this weekend. Will try to post some pictures of the finished plane next week. Thanks again.
WhiteKnuckles 04-02-2004 10:08 AM
Have someone who knows what their doing help you cover the wing. That way you'll get the washout right. Mine is screwed, yet the plane stills flies well. The PT-40 will fly regardless of what you screw up.
