RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Another Battery Question (https://www.rcuniverse.com/forum/beginners-85/6988927-another-battery-question.html)
RockEnRoller6 01-29-2008 07:48 AM
I hooked my hobbico 12V panel battery up lastnight for a overnight charge, as I was doing more work to my gear I started to notice that the battery itself was making odd sounds, like trickling water no more than a few min. since I hooked it up. So I discontinued the charging for the night. The battery is a lead-calcium battery and I was using a hanger 9 12V charger. My thought was it was a reaction to the current running through the battery since it was not charged. So if someone could explain to me what was going on and if it will be okay to continue charging.
Rodney 01-29-2008 10:57 AM
RE: Another Battery Question
What were you using to charge it with? Check out www.rcbatteryclinic.com for some good advice on charging all types of batteries. For your type, you need to use a charger that limits the current to about 0.1C (maybe get by with a little faster charge) to be safe and also be sure it is voltage limited so that you do not overcharge and ruin the battery.
RockEnRoller6 01-29-2008 02:55 PM
The charger I am using has an output of 600mA, I cant figure out why it was making those odd sounds.
