HiTec RX
Does HiTec RX have a low and high band like futaba? Or is it like the Newer Futaba RX that will accept both H and L
RE: HiTec RX
HiTec receivers work with all bands.
[link=http://www.rcuniverse.com/forum/m_3034623/anchors_3035642/mpage_1/key_low%252Cband/anchor/tm.htm#3035642]Check this thread.[/link] |
RE: HiTec RX
Don't think HiTec ever produced RXs that needed that hi/lo deal.
Matter of fact, they're making them now that work with either JR or Futaba TX's. They really have about the best value in 6 or 7 channel RXs on the market. I got both JR and Futaba TXs and RXs, but the majority of models have HiTec RX's in them. |
RE: HiTec RX
I wish the same could be said for 2.4 GHz RX's.
CGr. |
RE: HiTec RX
Yea!! I have a DX-7 buy only one RX. A bit pricey
RE: HiTec RX
As said, only Futaba has the band issue and even then the newer Futaba receivers have done away with that.
I like the Hitec Receivers. I use them alot with my Futaba TX. Make sure if you get one that it is compatable. Some Hitec receivers are set shift. Some are selectable shift and some are auto shift. Selectable and auto shift will work with any 72Mhz transmitter. |
RE: HiTec RX
Thanks for the info. How do I know what kind of shift they are. Talking about used ones
RE: HiTec RX
Ask the seller?
They should say right on them. Look the model number up. Here is a link to the Hitec website: http://www.hitecrcd.com/ |
| All times are GMT -8. The time now is 02:28 PM. |
