RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Tower Trainer 40 what's a good engine? (https://www.rcuniverse.com/forum/beginners-85/7083267-tower-trainer-40-whats-good-engine.html)
coindex 02-16-2008 12:31 AM
I bought a tower trainer 40 and a OSmax 40FP series engine. My questions to anyone are:
1. How well will this 40fp engine work in the tower trainer?
2. What manuevers will I be able to do with this engine? and
3. What props are best to use for breaking in this engine and flying?
NorfolkSouthern 02-16-2008 12:42 AM
RE: Tower Trainer 40 what's a good engine?
From my experience with the 40 LA and Hobbico Superstar, it should do loops (but not outside loops), rolls, and some inverted flight (you'll have to fight the dihedral). It won't go vertical, but the engine should be able to get the plane off the ground and do everthing within the plane's structural limits.
NorfolkSouthern
bigedmustafa 02-16-2008 12:47 AM
I've flown the Tower Trainer .40 MkII ARF. It's a wonderful airframe, but a typical .46 ball-bearing 2-stroke engine will make it very nose-heavy, even with the flight pack battery glued clear back into the tail section behind the servo tray.
The .40 LA has been discontinued by O.S., but the .46 LA is almost as lightweight. The O.S. Max .46 LA or Thunder Tiger GP-42 2-strokes are both excellent choices and relatively inexpensive. They will both also provide plenty of power while still allowing you to balance the plane on the recommended CG without having to add weight to the tail.
If you decide you'd rather have a ball-bearing engine or a 4-stroke, consider a .36 2-stroke ball-bearing engine from Evolution or Thunder Tiger, a Super Tiger G-34, or any of the .52~.56 4-stroke engines available from Saito, O.S., Magnum, or Thunder Tiger. The Tower Hobbies .40 MkII ARF is lightweight and has plenty of lift, any of these engines would allow a full range of aerobatics while meeting the weight requirement for ideal balancing.
Good luck, and good shopping!
Oops, I'm an idiot. I swear the part about you already owning a .40 FP wasn't there when I first read the thread!
The .40 FP should be a terrific match. You'll want to try a 10x6 and an 11x5 prop to see which you like the best. The 10x6 will give you a little more speed, the 11x5 will be slightly slower in the air, but will give you quicker take-offs and slower landing approaches.
The .40 FP should provide plenty of power for inside loops, barrel rolls, wing-over turns, and all of the other standard aerobatics that you will want to practice.
Missileman 02-16-2008 11:50 AM
My neighbor has exactly that combo and I have a Kadet MKll with the 40FP.
10x6 is the prop of choice. I recommend Master Airscrew for a trainer.
The plane and engine combo will do most of your basic aerobatics. It will have limited vertical but will have enough for loops, emmilmans, Cuban 8 ect...
