Freedom Firebird, Commander 2, Skyfly, or Slo-V ???
Those are the choices I've settled on. Here are the circumstances. I want a beginner type plane that I can fly in a relatively small area (soccer field size) that is surrounded by trees. I want a plane that isn't so fast that I am constantly battling the boundaries. I don't know how fast they planes are in reality...or in comparison to each other. Which one of the planes would be slow enough to tinker around in a relatively small area? Thanks Rob |
RE: Freedom Firebird, Commander 2, Skyfly, or Slo-V ???
Any of those choices would be hard to keep out of the trees surrounding a soccer field until you learn to control it.
Out of your list the Hobbico Skyfly would be my choice. |
Thanks, Missileman. What would be the issue with a slo-v...wouldn't that be slower (and thus easier to control) than a glider-typer plane like the skyfly? Trying to understand the pros and cons.
"I don't know how fast they planes are in reality..."
I can't comment on any of the specific planes, but the answer to the above question: about 2x as fast as you think, if you've never seen one! None of these planes is really fast, all under 40mph, I think, but it'll seem awful fast to a newbie. Most people don't realize how fast a 4' long plane doing 60mph really is! J |
The slow V is not much of an airplane at all. Waste of money IMO. it is only 2 channel with throttle controlling the altittude.
Skyfly gives you 3 channel control so that Elevator controls alltitude. This gives you much more control over the airplane plus it even mixes rudder and elevator for the beginner. My opinion? If I was looking at the Slo-V I would be just as well off buying a $30ish Airhogs from Walmart. |
The slow V is not much of an airplane at all. Waste of money IMO. it is only 2 channel with throttle controlling the altittude. Skyfly has a rudder and a single elevator. Slo-v does not have a rudder but does have two elevators...and the v-tail...so altitude is not only controlled by the throttle. They both are 3-ch proportional. |
Thanks, Jburry. I think you are right, they all probably go faster than one thinks.
ORIGINAL: RTice The slow V is not much of an airplane at all. Waste of money IMO. it is only 2 channel with throttle controlling the altittude. Skyfly has a rudder and a single elevator. Slo-v does not have a rudder but does have two elevators...and the v-tail...so altitude is not only controlled by the throttle. They both are 3-ch proportional. Got a few more dollars the Hobbyzone Super Cub is better yet. |
ORIGINAL: Missileman ORIGINAL: RTice The slow V is not much of an airplane at all. Waste of money IMO. it is only 2 channel with throttle controlling the altittude. Skyfly has a rudder and a single elevator. Slo-v does not have a rudder but does have two elevators...and the v-tail...so altitude is not only controlled by the throttle. They both are 3-ch proportional. Got a few more dollars the Hobbyzone Super Cub is better yet. I just flew my Firebird Commander 2 for the first time. It's not a bad little airplane, but there are a few problems with it. First off, if the wind is anything more than 5 MPH, don't fly. You will end up on the ground faster than you left it. Second, make sure you TURN OFF the A.C.T. It is of little to no help, and as far as I am concerned, it holds back a new pilot from really learning the basics of flying the airplane. Also, it seems to be quite nose heavy and will need some weight in the tail. If you haven't yet gotten an airplane, I would recommend the F-22 Raptor PTS from Hangar 9. It's gotten some bad raps because of the lower power it posesses, but that can easily be changed. Also, you will need to fly the airplane right down to the ground. They also have a great looking P-51 PTS, also an excellent beginner plane. I have both, and they are both ALOT of fun to fly, and BOTH can be switched into really great sport planes once you have mastered them with the PTS equipment still on them. Steve |
| All times are GMT -8. The time now is 02:03 PM. |
