RE: thread lock on servo screws?
Btw red can be removed very easily with a bit of heat. Just use a soldering iron in the screw head for a few seconds and its gonna be like there was never any loctit there...
Like most of you that responded to this thread.....I have never had a servo arm keeper screw get even loose......but.....if you're worried about it.....I wouldn't over-kill it with thread lock....instead....a little dob of varnish or fingernail polish on the screw wouldn't hurt....and besides.....when you need to remove the screw, a little acetone will release it. Down pressure with your phillips screwdriver is NOT good.
Flash |
Carefull with the acetone. It will melt many plastics. Used to make plastic cement by putting plastic chips in acetone till it melted. Safer to use nothing.
| All times are GMT -8. The time now is 03:46 AM. |
