RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Battery check/charge (https://www.rcuniverse.com/forum/beginners-85/728388-battery-check-charge.html)
TailDraggin 04-28-2003 10:50 AM
What do you use to check your receiver battery? All I saw in the Tower catalog were two on-board micro units.
I'm looking for something to plug in to the charging pigtail (Hitec) that will tell me if I need to recharge.
Also, my wall wart AC charger takes 16 hours to do a charge according to the radio manual. Is there a quicker (but safe) way?
darenm 04-28-2003 11:10 AM
i guess this is 1 of the things you say you don't want. But i must tell you this thing is awesome and it doesn't weigh a thing. And for the price you can't beat it.
Volt Watch
http://www2.gpmd.com/image/h/hcap0330.jpg
RedWing 04-28-2003 12:14 PM
You could get a field charger.
I got one at www.servocity.com
Hitec CG-340 Peak Charger.
This way you can charge at the field or before you go.
There are a bunch of options for chargers, this one is real cheap at $34.95 and free shipping.
You will need to get some banana clips and the appropriate connectors for you radio and receiver batteries.
Bill
Steve Guinn 04-28-2003 12:23 PM
http://www2.towerhobbies.com/cgi-bin...?&I=LXWW16&P=7
You will need to get Hitec leads.
Steve Guinn 04-28-2003 12:29 PM
http://www.siriuselectronics.com/
You can get the Pro from Central Hobbies or Heliproz for $109
Why do I get the feeling you already know the answers to these questions?
TailDraggin 04-28-2003 04:12 PM
Originally posted by Steve Guinn
Why do I get the feeling you already know the answers to these questions? [/B]
I don't know, but I don't.
Thanks for the info.
Charlie P. 04-28-2003 05:38 PM
The digital one probably works better, but for less you can get the Hobbico Analog ESV
http://www2.towerhobbies.com/cgi-bin...p?I=LXNK81&P=7
I keep one of these in my flight box and it works very well. I made a bannana to Futaba J connector so I can plug it into the charge ports of my aeroplanes.
TailDraggin 04-28-2003 06:20 PM
Charlie,
Got an "invalid part number" message from your link and a "no matches" on an item search for "hobbico analog esv".
Charlie P. 04-28-2003 06:26 PM
http://www2.towerhobbies.com/cgi-bin...?&I=LXNK81&P=7
They the above. The Tower part number is LXNK81
TailDraggin 04-28-2003 06:32 PM
That worked. Thanks, Charlie.
paul_c 04-28-2003 08:41 PM
I second Steve's recommendation. It is quick (as they all are) but there is no thought process involved. Just plug in--when done, it blinks. And when the batt. is recharged, the unit switches to a "pulse" charge which is supposed to recondition the battery (I don't know if it actually works, but I believe it IS better than a trickle charge, which is what most other units do)
