Servos
I use JR servos and I came across some FMA S360 servos. The wires are a different color. Question is, I want to put JR ends on the FMA servos so how do I figure out which wire is which.
Thanks in advance |
RE: Servos
black or dark brown is usually the ground, power is in the center, and signal is opposite the ground.
Why do you want to put different connectors on them? With the exception of shaving the tabs off the futaba so they fit jr/spectrum, most of them today all work with the different receivers. |
RE: Servos
1 Attachment(s)
Barracuda is correct, just shave off the tab and they will work fine. You don''t need to put new ends on them.
Ken |
RE: Servos
Thanks guys
| All times are GMT -8. The time now is 11:01 PM. |
