RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Elevator (https://www.rcuniverse.com/forum/beginners-85/739139-elevator.html)
kyrcnewbie 05-02-2003 02:42 PM
Elevator
I just purchased and put together a Hobbico Superstar 40. Everything seems to be in good shape, I balanced it, etc. but I have one nagging problem. The instructions recommend 1 inch of elevator movement from dead center. I have moved the connector to the bottom of the horn, but am only gett ing about 1/2 inch of movement. Everything else has the recommended movement length. Is the 1/2 inch enough to start with, or do I need the full 1 inch? Any advice on fixing this problem, if it is a problem.
mjd3 05-02-2003 02:43 PM
Elevator
Try moving the control rod out on the servo arm.
tempus 05-02-2003 03:09 PM
Elevator
Try it with the travel it has now. Usually for learning extreme movement of the elevator is not necessary.
kyrcnewbie 05-02-2003 03:38 PM
Elevator
Thanks for the quick reply. I figured more is not better for starters. Thanks tempus and mjd3. Another question, how much runway is needed for a starter plane? I have seen people get ariborne in as little as 75 feet, and some as much as 200 feet? What size runways do most fields have?
tempus 05-02-2003 03:49 PM
Elevator
The runway at my club is about 350 feet long but my plane needs about half the length to get airborne. It depends on the plane of course. An acrobatic plane like some I have seen at my club can lift in a short distance, maybe 1/5 of the runway length.
AdmiralHam 05-02-2003 04:30 PM
Elevator
I just flew my SuperStar 40 for the first time last weekend. At full throttle, using an OS .46 FX, the plane took off in less than 20 feet. The run way at my field is a little bumpy, so I replaced the foam wheels that came with the ARF with larger diameter rubber wheels. A PT-40 with the foam wheels had some trouble getting into the air.
Phi3l 05-02-2003 04:50 PM
Control deflections.
kyrcnewbie,
I just looked on the Tower Hobbies web sight and found the SuperStar 40 manual.
Here is what I found listed for control throws:
Elevator 1/2" up 1/2" down
Rudder 1" left 1" right
Ailerons 7/16" up 7/16" down
So your 1/2" each way is right on the nose.
Hope this helps,
Phil in MN
MinnFlyer 05-02-2003 05:37 PM
Elevator
you might not need much room to take off, but don't forget that you have to land too!
DBCherry 05-03-2003 02:01 AM
Elevator
Usually true, but....
kyrcnewbie,
You're asking about field size. Please tell me you aren't about to try flying this on your own. :( If you are, you may only need about six square feet to land. (You'll most likely be coming straight in!) :eek:
