RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   ultracote question (https://www.rcuniverse.com/forum/beginners-85/7417888-ultracote-question.html)
2slow2matter 04-25-2008 09:39 AM
ultracote question
I know this is a stupid question, but it was brought up to me the other day and I want to make sure. I'm using a DX7 radio, and I know that 2.4 gHz don't like carbon fiber. I'm wanting to cover the bottom of my wing with ultracotes fiber carbon covering. I'm quite sure this is just a print and there is actually no carbon in the covering itself, but does anyone think this will cause interference?
I think I'll wrap a rx in several layers of the covering and do a range check at home just to make sure, but what do you guys think? I've already covered the front deck of the plane in the stuff, and I really like how it looks. Matched with a carbon fiber prop and aluminum spiner, this thing will look good, but I don't want to block out the rx signal by covering the bottom of the wing if that is what will happen.
alfredbmor 04-25-2008 10:43 AM
RE: ultracote question
ORIGINAL: 2slow2matter
That is a good idea.
I have read at some forums around here that indeed there is an interference between the Tx and Rx when using some kind of material (Aluminum covering) for covering that could impede the signal to reach each other. Remember that FM signals can travel trough walls but 2.4 ghz signal can drastically be interfered by a thick wall or in this case a type of covering that could difficult the reach of the signal. Even that this type of situations are very rare, your idea of covering the Rx with some layers of that particular material is great and I am very interested in knowing your results.
RCKen 04-25-2008 11:03 AM
If I had to venture a guess I would say that the "carbon fiber" is just a print on the actual Ultracote. But it wouldn't hurt to be safe. Do the checks you mentioned. I would also call Horizon/Hangar 9 and ask them just in case.
Ken
Gray Beard 04-25-2008 04:20 PM
It's just A print. Looks really cool though.
