RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Spinner Size (https://www.rcuniverse.com/forum/beginners-85/743527-spinner-size.html)
FatCat 05-04-2003 04:39 PM
Spinner Size
I have a Hobbico superstar with a TT .46 motor and I am looking to install a plastic spinner on it. Right now I have a dome nut, but want to convert it. The problem I am having is my LHS claims the only have car guys available to help me, and they are not sure what size I need. Can anyone help me out here???
Schubox 05-04-2003 05:50 PM
Spinner Size
Use a 2" or 2 1-2" either or will work plenty good. If you are worried about diameter on the shaft it doesn't matter the spinners come with spacers.
Barland 05-04-2003 10:38 PM
Spinner Size
Make sure the prop is NOT touching the edges of the cut out on the spinner! This will help avoid damaged spinners and props. It may require that the spinner be trimmed a bit to allow the prop to clear, do it equally on both sides to keep things in balance. I bit of extra space doesn't seem to be a problem so keep it equal on both sides.
Geistware 06-14-2003 08:57 PM
Spinner Size
Just get a propeller that fits the profile of the spinner on the cowl. THat is going to be your best rule of thumb.
