RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   engine spacing (https://www.rcuniverse.com/forum/beginners-85/7483592-engine-spacing.html)
iraqvet 05-11-2008 03:38 PM
engine spacing
I bought a Magnum .46 (replacement engine for a OS .40) for my Tower Trainer. If I shove the new engine back to get the spinner to firewall spacing recommended in the manual, the fuel lines get a little pinched. Would I be OK moving the engine foward a bit or can a 90 degree elbow be installed off the tank to avoid the pinching?
RCKen 05-11-2008 03:52 PM
RE: engine spacing
You can move it forward a bit to get some clearance for your fuel lines. Just make sure to check your balance because moving the engine forward will more than likely shift the CG forward a bit. Other than than, you'll be fine.
Ken
beau0090_99 05-11-2008 08:58 PM
RE: engine spacing
Ken,
I did the same with my Sealane that I am building to avoid kinking the fuel tubes and to move the balance a bit forward. I moved it 1/4" is there a general rule of thumb as to how far you can move it (of course, without taking into account CG issues)? I figure, if the mount is long enough and the firewall is strong enough, should it matter much?
Curtis
RCKen 05-11-2008 09:03 PM
RE: engine spacing
ORIGINAL: beau0090_99
Ken,
Curtis
That's a pretty good rule of thumb. You should be ok.
Ken
