Newbie Engine Question part2
yup, here we go again ;D I'm in the process of trying to tune my new engine (Tower .46) And when its at idle its vibrating, and quite a bit, tailfeathers and all. I'm just wondering what would cause this? I'm assuming it isn't normal. could it be set too rich on idle? Thanks for all the help :D
Cheers, Derek |
RE: Newbie Engine Question part2
possibly due to too rich is one. Out of balance prop another.Unsecure motor mount. Try adjusting the idle screw.
They will vibrate quite a bit at idle though. |
Wouldnt think vibration from that engine would be THAT noticable. Make sure your prop is balanced very well,and make sure theres not something wrong with your spinner that would throw it out of balance or something. Other than that,everything should be normal and maybe thats just the way it is. It could be really rich,but I wouldnt even think that would be so noticable on that size engine,but anything is possible.
It's quite possible it's just a reaction from the model to the firing impulses from the engine. Every time the engine fires the torque reaction feeds back into the model and maybe the wing or tailplane is acting like a tuning fork and resonating. Sometimes just using a different prop can cure it by making the engine run at a different speed at idle.
ORIGINAL: downunder It's quite possible it's just a reaction from the model to the firing impulses from the engine. Every time the engine fires the torque reaction feeds back into the model and maybe the wing or tailplane is acting like a tuning fork and resonating. Sometimes just using a different prop can cure it by making the engine run at a different speed at idle. This is known as "Harmonic Vibration" Everything in the world wants to vibrate at a certain frequency - This is how a Microwave oven works. The magnatron sends radio waves at the same frequency at which water molecules vibrate. The molecules vibrate and create heat and your food cooks. Or look at Downunder's analogy to a tuning fork - If you have a tuning fork which is tuned to an "A", and you play an "A" on an instrument, the tuning fork will vibrate because it is getting hit with vibrations that are the same frequency at which it is designed to vibrate. So what's happening is your engine is vibrating at the same frequency that your tail wants to vibrate. Now this can be caused by only one thing - the vibrations put out by your engine. Being rich has nothing to do with it. An unbalanced prop MIGHT be the culprit, so try checking it's balance first. Otherwise, your only options are: 1) Idle at a different RPM 2) Redesign your tail so it vibrates at a different frequency 3) If the prop is balanced, try unbalancing it slightly and put the heavier end opposite the piston at Top Dead Center. |
Have you broke in your new engine? you aren't doing yourself or your engine any favors tuning it before you have broke it in....
Seconding (???), Downunder's and MinnFlyer's posts...
The T.H. is no more prone to vibration than any other engine. As indicated, balance your prop & spinner. You may also need or want to re-do your engine mount. It may be contributing to this. At worst you can also utilize a Dubro anti-vibration mount. When I put these on planes, almost no harmonic vibrations get translated back into the fuse. If you put your hand on the fuse you can barely feel the engine running at any speed. This will make your plane last longer too. |
ORIGINAL: opjose Seconding (???), Downunder's and MinnFlyer's posts... The T.H. is no more prone to vibration than any other engine. As indicated, balance your prop & spinner. You may also need or want to re-do your engine mount. It may be contributing to this. At worst you can also utilize a Dubro anti-vibration mount. When I put these on planes, almost no harmonic vibrations get translated back into the fuse. If you put your hand on the fuse you can barely feel the engine running at any speed. This will make your plane last longer too. |
| All times are GMT -8. The time now is 03:50 AM. |
