RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   After run drips out of engine...normal? (https://www.rcuniverse.com/forum/beginners-85/7555558-after-run-drips-out-engine-normal.html)
Jetdesign 05-29-2008 11:49 AM
I just found a little puddle of oil under my plane, well actually found its been growing, and is a result of after run dripping from what looks like the bearing location, just behind the prop.
Is that normal?
Thanks.
Campy 05-29-2008 12:03 PM
RE: After run drips out of engine...normal?
If you have the plane/engine in a nose down position it is normal. You may also have exhaust residue/oil occasionally dripping from the muffler outlet.
I either store my planes horizontally or put an old rubber car floormat under the nose of the plane on the ones I hang nose down I also stick a piece of rolled up paper towel in the end of the muffler.
ChuckW 05-29-2008 12:10 PM
That's not uncommon. I have a few nice spots on the garage floor where my planes have dripped oil. I try to put pieces of paper towel in the muffler outlet but there is always a little than manages t come out from other areas.
brett65 05-29-2008 12:12 PM
It's gotta go somewhere, thats just the excess that didn't coat onto the inside of the motor. Same thing happens to my nitro cars sometimes.
Jetdesign 05-29-2008 12:52 PM
The muffler is plugged, it's definitely not coming out of there.
The plane is stored horizontally on a rack. There is clearly red after run dripping from the front of the case.
Sounds like nothing to worry about though. Thanks.
opjose 05-29-2008 01:33 PM
Most front bearings are NOT "sealed", so it is perfectly normal for fuel or oil to drip out.
Jetdesign 05-29-2008 01:48 PM
Thanks Opjose.
