taking off
wen im taking off, and my plane twists to the left, shuld i use rudder, or aileron to get it back straight, and how much shuld i us
thanks, daniel |
RE: taking off
Using rudder, especially around the landing strip, is great practice. Not enough people use rudder, or at least use it enough. You should be using rudder to keep in line with the strip on landing, so why not use it to keep in line on take off? Now if your plane is really rolling as it pulls to the left, then of course aileron will be needed to keep the plane level.
Good question. This is obviously my opinion, so it will be interesting to read the other responses. |
RE: taking off
It depends on what you mean by "twist". If the plane is turning left or right, then yes you want to use the rudder to correct. But if the wings are dipping as in a roll, then you want to use the ailerons to correct it.
Ken |
RE: taking off
thank u 4 ur advise, it shuld help me not crah on take-off agian
RE: taking off
Does your plane "twist" while still on the ground? If so, then you need to apply rudder to correct. Are you familiar with the terms "roll", "yaw" and "pitch"? When taxiing on the ground, your model can only "yaw" left or right. Yaw is when the nose of the model turns left or right. Pitch is when the nose points up or down. Roll is when the nose stays put but when one wingtip goes up and the other goes down. This is also called banking. Roll, or banking, you correct with the ailerons.
If your model is turning (yawing) suddenly after taking off, then your nosegear or tailwheel is misaligned. |
RE: taking off
dont worry, i now the terms, im a pilot (of a cessna 172), but im new to model airplanes.
RE: taking off
ORIGINAL: daniel pedersen dont worry, i now the terms, im a pilot (of a cessna 172), but im new to model airplanes. Ken |
RE: taking off
gtotcha, but when i watch videos of rc, they do alot more than my cessan, thay hover, like come on, when do you see a real plane hover, so i thought that maybe rc was way different, thank you for ur insight to my problem
RE: taking off
ORIGINAL: daniel pedersen gtotcha, but when i watch videos of rc, they do alot more than my cessan, thay hover, like come on, when do you see a real plane hover, so i thought that maybe rc was way different, thank you for ur insight to my problem Ken |
RE: taking off
Full scale flight doesn't help with R/C much. When was the last time you flew a full-scale airplane while it was heading AT you?
If it's a nose-wheel trike have you ground-checked it so it rolls straight with the rudder centered? Common error is to have the nose wheel out of line with the rudder so they fight each other. The nose wheel has a lot more authority while in contact with the ground, but the instant you rotate if it is not set to the rudder the model suddenly turns when the rudder gets the airflow to be in command. There is also a natural tendency to wander to port from the prop torque. Taildraggers, and in particular narrow carriaged biplanes need a bit of right rudder to compensate. Feed in throttle smoothly and gradually. Flooring it gives a lot of torque before the windspeed over the control surfaces gives you any control authority. |
RE: taking off
ORIGINAL: Charlie P. Full scale flight doesn't help with R/C much. When was the last time you flew a full-scale airplane while it was heading AT you? If it's a nose-wheel trike have you ground-checked it so it rolls straight with the rudder centered? Common error is to have the nose wheel out of line with the rudder so they fight each other. The nose wheel has a lot more authority while in contact with the ground, but the instant you rotate if it is not set to the rudder the model suddenly turns when the rudder gets the airflow to be in command. There is also a natural tendency to wander to port from the prop torque. Taildraggers, and in particular narrow carriaged biplanes need a bit of right rudder to compensate. Feed in throttle smoothly and gradually. Flooring it gives a lot of torque before the windspeed over the control surfaces gives you any control authority. |
RE: taking off
ORIGINAL: gaRCfield ORIGINAL: Charlie P. Full scale flight doesn't help with R/C much. When was the last time you flew a full-scale airplane while it was heading AT you? If it's a nose-wheel trike have you ground-checked it so it rolls straight with the rudder centered? Common error is to have the nose wheel out of line with the rudder so they fight each other. The nose wheel has a lot more authority while in contact with the ground, but the instant you rotate if it is not set to the rudder the model suddenly turns when the rudder gets the airflow to be in command. There is also a natural tendency to wander to port from the prop torque. Taildraggers, and in particular narrow carriaged biplanes need a bit of right rudder to compensate. Feed in throttle smoothly and gradually. Flooring it gives a lot of torque before the windspeed over the control surfaces gives you any control authority. If you did, then you've essentially trimmed in some yaw in the rudder in order to get the nosewheel straight. Rather than using trim to adjust the nosewheel for a straight takeoff run or roll out on landing you should use the nose wheel linkage to adjust for straight roll. This leaves the rudder trimmed properly so you don't see a sudden yaw as the rudder gains effectiveness either while still on the ground or just at take off. My rudder/nose gear servo has a "slide through" type linkage at the servo for the nose gear pushrod. That allows me to loosen the set screw and move the pushrod forward or backward to straighten the nose wheel, while not affecting the rudder at all. Bob |
RE: taking off
ORIGINAL: mitchell170 Did you use trim to straighten out the roll on the ground? If you did, then you've essentially trimmed in some yaw in the rudder in order to get the nosewheel straight. Rather than using trim to adjust the nosewheel for a straight takeoff run or roll out on landing you should use the nose wheel linkage to adjust for straight roll. This leaves the rudder trimmed properly so you don't see a sudden yaw as the rudder gains effectiveness either while still on the ground or just at take off. My rudder/nose gear servo has a "slide through" type linkage at the servo for the nose gear pushrod. That allows me to loosen the set screw and move the pushrod forward or backward to straighten the nose wheel, while not affecting the rudder at all. Bob |
RE: taking off
ORIGINAL: daniel pedersen wen im taking off, and my plane twists to the left, shuld i use rudder, or aileron to get it back straight, and how much shuld i us thanks, daniel If it rolls, use aileron. If it yaws, use rudder. Use enought to straighten it out. |
| All times are GMT -8. The time now is 09:15 PM. |
