RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Quick question.. 2 elevator servos (https://www.rcuniverse.com/forum/beginners-85/7597022-quick-question-2-elevator-servos.html)
ErikElvis 06-09-2008 12:04 AM
I recently bought a goldberg sukhoi with 2 elevator servos mounted on the outside of each side of the fuse. Instead of looking at it in the other room Id figure Id post. Do I just need a standard Y harness to hook it up or a reversing Y? I dont feel like thinking right now... [sm=red_smile.gif]
Erik
RCKen 06-09-2008 12:12 AM
RE: Quick question.. 2 elevator servos
You will need to use a reversing Y-harness. Or if you have a computer radio that can handle dual elevator servos you can use that as well.
Ken
ErikElvis 06-09-2008 12:28 AM
Thanks for the reply. Any real advantage to using 2 channels for the elevators? I do have a JR X9303
RCKen 06-09-2008 12:35 AM
If you have the X9303 then I would use the radio to do it. Reversing Y-harnesses have a habit of the centers drifting on the servos. The advantage of using the radio is that you can adjust each servo to trim them in using only the radio. Trust me, you'll be much better off using the radio over the Y-harness. Plus, it will save you the money of not having to buy the Y-harness.
Ken
ErikElvis 06-09-2008 01:39 AM
Thanks again. One more question Know the difference between JR sport extensions and the "gold" or whatever extensions?
MinnFlyer 06-09-2008 07:47 AM
For most applications, the standard extensions will be fine
JohnBuckner 06-09-2008 09:49 AM
====OR====
If the stabilizer position permits when using an ordinary Y chord you can just terminate the pushrod on one side toward the bottom of the servo and on the otherside toward the top of the servo. Nothing additional needed.
JohnBuckner 06-09-2008 09:51 AM
Missileman 06-09-2008 02:12 PM
ORIGINAL: RCKen
Although I only have one airplane with dual elevator servos they are hooked up via a reversing Y harness and I have not had any drifting at all.
2slow2matter 06-09-2008 05:25 PM
I've never had one that didn't drift. I hate them, and have removed and thrown all of them in the trash. I use only my radio for mixing now....
alfredbmor 06-09-2008 07:03 PM
ORIGINAL: ErikElvis
Yes, many. The first that comes up to my mind is that you will be saving some bucks because you will not need any Y harness.
Campgems 06-10-2008 12:04 AM
John, I've seen a couple different ARF's at the field lately with that configuration. Looks awful, but the geometry is OK.
Don
ErikElvis 06-10-2008 12:09 AM
Thanks guys. I think Ill just get a couple extensions and let the radio do the work. And while im at it probably do the same with the airlerons.
