RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Did I stall??? (https://www.rcuniverse.com/forum/beginners-85/7644982-did-i-stall.html)
Jetdesign 06-21-2008 02:37 PM
Did I stall???
I guess I'm curious what a stall looks like, I might have done one, twice, without knowing it.
Coming in for a landing, once on Wednesday and one today, I was turning in to final, when my plane got "hit". I thought I lost total control, and the plane turned completely around and ended up flying away from me, doing some pretty wild moves. My stick corrections seemed to have little to no effect. Since I was coming in for landing, I was low on power. I throttled up so my corrections would have more effect, and was able to safely bring the plane in to land. Almost lost it today.
Driving home, I realized that maybe I stalled? I couldn't get control until I gave it more throttle, so maybe it was in a stall condition the whole time, and I really wasn't getting hit.
Only thing, though, is that all day I was just flying above idle, getting used to low flight characteristics, and shooting touch-and-gos, getting used to my plane. I think I would have known if I was too low on throttle, and I know I was a few clicks higher than when I was coming in as slow as possible. But then there's always the possibility of a gust of wind changing everything. Was at the point of the plane being pretty mushy responding to controls, maybe pretty close to stall speed, but again, I feel like I would have known that. Maybe not.
Does this sound like a stall? My trainer said I was in a spot known to interfere with 72mhz radios though. I range check fine, but then brought the plane physically to the spot where it happened, and left the radio with a guy at the flight line. Just as I got past the end of the runway, the servos started to make some noise. No control surface movement, but definitely a groaning noise coming from the electronics. Plane flies absolutely fine anywhere else, and at plenty of distance, but this happened just long of one end of the runway, again during approach.
So I was wondering if people could talk about what happens when a newbie first encounters a stall; what happens to the plane, how do they react, and is it similar to this?
Thanks guys!
ply2win 06-21-2008 02:58 PM
RE: Did I stall???
The way a plane behaves in a stall is different depending on what type of plane it is. However, your statement that you were able to control it again after you gave it throttle makes me believe it was a stall. It also could be that you were overcontrolling the plane when it was too slow.
If you had lost control of the plane due to interference the throttle wouldn't work properly either. I hear a lot of people talking about getting "hit" but I have yet to experience that in 3 years of flying at several different fields.
If the wind allows, you could always try and land from the other direction and see what happens.
Campgems 06-21-2008 03:11 PM
RE: Did I stall???
Each plane has it's own stall behaivor. Some drop their nose and start down. Some will tip stall, one wing quits flying and it rolls into a knife edge and goes in. Some planes give you warning, musshy controls and loss of stability. Others just drop.
What you describe sounds like it was about to stall but hadn't got quite to it yet. You are very lucky to have recovered it.
I lost my 4*60 a couple months back, doing just as you describe. I had a strong head wind straight down the runway. I was throttled back more than I should have been, I was gaging the ground speed, not air speed. When I started my final turn to quick and then turned back to correct my approach, I had no air speed. My 4* just dropped it nose and went down like a lawn dart with no warning. I've watched a couple guys drop their Yak 54 and Extras by using flaperons and not taking into account that a quick aileron change could stall out the wing. Wing over at 20 ft and then pick up parts.
It would be a good idea to practice stalls. Way up high go you can recover. Just setup on a straight line and keep cutting power and applying more up elevator until it starts it drop. Pour on the coal and accelerate out of trouble. See how the plane handles. Try it both up wind and down wind. The key thing is to gain airspeed as soon as you can.
Don
ChuckW 06-21-2008 03:13 PM
RE: Did I stall???
Your Dolphin should have good stall characteristics. I would think it should anyhow based on the overall design. Most planes like that I have flown with constant chord wings, big wing area and the light wing loading that results tend to stall pretty gently. The GP Cherokee for instance just sort of tips forward a little, picks up speed in the descent and starts flying again. Nothing scary about it at all unless you are right on the deck. You REALLY have to try and make that happen too; it is hard to stall. Same goes for a 4-star. I've never intentionally stalled one but they seem to float along forever going slower and slower without stalling.
Other airplanes are a different story. Get them too slow and they'll drop a wing & snap into the ground or just suddenly fall out of the sky. That's why a lot of really aerobatic planes aren;t good for beginners. That ability to stall easily helps in many maneuvers but can be dangerous for an inexperienced pilot.
Never having flown a Dolphin, I really can't say how it stalls.
To me it sounds like either a serious radio hit r a case of over-controlling. Could be dumb-thumbs too; we all suffer from that on occasion.
Another thing to remember is keep the nose down slightly on your approach. This helps keep airspeed up and the wing flying. Rotate to level when you are just a few feet off the ground.
opjose 06-21-2008 03:39 PM
RE: Did I stall???
ORIGINAL: ply2win
A "hit" tends to cause ALL control surfaces to deflect randomly or in different directions.
Usually the plane will be flying along at normal speeds when it will suddenly and inexplicably change orientation, throttle, pitch, etc.
Even when it's heading toward the ground at high speed, the surfaces will appear to have no effect as they may not be active.
Gusts can sometimes be misinterpreted as "hits", particularly when a sudden gust flips the plane over. A seasoned pilot is able to quickly recover control, but a rookie may find things happening way too fast.
Usually a gust of wind will change the orientation only in one or two directions w/o a sudden decrease or increase in throttle.
Jetdesign 06-21-2008 03:45 PM
RE: Did I stall???
Hmm. I definitely was flying the plane all afternoon really close to, if not at, stall speed. I was flying where I had to keep the nose pointed maybe 20 to 30 degrees up, using lots of elevator, and the plane was still sinking. Tip stalls would happen, and power and/or opposite aileron would correct it.
What gets me about what happened is that the plane completely got turned around and was flying away from me, and was rolling and almost looping on its own. I guess it's hard to say what happened. I think/imagine the stall characteristics of the plane are pretty gentle, at least from what I have seen so far. I can't imagine the plane turning itself around from a stall, in the opposite direction that I was turning in to final from.
Dunno. I guess some more investigation to noise in that area is a must.
I did bring it around to the other side of the field to land it. Unfortunately I don't know if/when the throttle kicked in, if it did it immediately or not. I was struggling with the plane for quite a while, and actually think the throttle might have kicked in later, when I regained control, but can't really remember.
ChuckW 06-21-2008 03:53 PM
RE: Did I stall???
ORIGINAL: gaRCfield
What you are describing is called a harrier in the 3-D world. A plane like the dolphin really isn't meant to be flown like that. With that slow speed and high angle of attack, you almost certainly stalled the airplane. When you cut the throttle, keep the nose slightly down to maintain enough airspeed to keep the wing flying. Then slowly add up elevator to level out and stay that way a feet above the runway when landing.
In my opinion, I would stop this type of high alpha flight with that particular airplane. It isn't designed to do it and you won't ever learn to fly well doing it either. Remember... straight and level, precision, control, good landings, etc. make a good pilot. Master those first. Save the crazy stuff for a few planes and some time from now.
Campgems 06-21-2008 03:58 PM
RE: Did I stall???
Are you flying a PPM or PCM receiver? You may have gone into a brown out and the receiver shut down for a couple seconds. Lot of flying that day could have left you with a battery that wasn't 100% and you happened to induce a little extra load and tripped it off.
Just a thought. It would explain your trun also as the controls would lock where you had them last. A little aileron and around you go.
Don
OzMo 06-21-2008 04:03 PM
RE: Did I stall???
Watch the other pilots land and look for a wag of the tips. This is a clue airspeed is marginal. The seasoned guys will allow the nose to drop to keep airspeed and control or blip a little throttle. remember the ELEVATOR controls airspeed on approach!
Try a blip of gas as the plane is settling into the flair, the air presure increase when the plane is so close to the ground really softens the landing.
Also try some 20' high stalls close in so you can see how the plane reacts. Do several and play with the elevator fine inputs.
After a few of these the little light in the back of your brain will come on!
Hypersprint 06-21-2008 04:05 PM
RE: Did I stall???
ORIGINAL: gaRCfield
//snip//
Sounds like you might be getting close to doing a Harrier
I guess I need to learn to type faster
Jetdesign 06-21-2008 04:50 PM
RE: Did I stall???
Well the 'high alpha' flight was me just trying to figure out what happens to my plane in different situations; I don't normally fly that way, nor was I flying that way when I had whatever happened happen to me. I was turning into final with the nose maybe 5 degrees down when it happened. I just brought that up because I was trying to learn stall characteristics, so I was trying to get into a stall situation, and was trying to explain that I didn't think I was that close to a stall. When I did that, the wings wanted tip, and the plane wanted to sink. I kept it up as long as I could with low power, then pulled out with some throttle.
I have PPM (FM) receiver. 2300mah battery, and Voltwatch showing second to highest green bulb. Is PPM better for this kind of stuff? Is it worth spending $100 on a new receiver?
bkdavy 06-21-2008 05:02 PM
RE: Did I stall???
I would say you were definitely stalled.
Another aspect of stall recovery that many beginners are not used to: Once the wing stalls and the plane starts to spin, ANY control inputs other than throttle are going to deepen the stall. That is why stalls are frequently mistaken for radio hits. With a stalled wing, adding aileron will not have the normal effect, and that feels like a radio hit. Same with elevator and rudder. In fact, the control inputs make the gyrations of the plane seem worse. Thats how you ended up turned around.
When you're landing, try to keep the nose level, or maybe one or two degrees up. This will help keep you away from the stall condition.
Brad
Campgems 06-21-2008 05:23 PM
RE: Did I stall???
ORIGINAL: gaRCfield
You should have been good to go. The slow startup is with a PCM. So we can scratch that off the list of posibilities. I think the stall vote are wining this poll.
Don
ChuckW 06-21-2008 06:24 PM
RE: Did I stall???
One other thing to consider... is this the same receiver that has been through 2-3 crashes? If so, did you get it checked out and repaired if needed? I witnessed what happens when you fail to do this a few weeks ago. A guy at my club had a beautiful GP Shoestring and used a receiver from a crashed airplane. In spite of experiencing a couple glitches in a previous flight, he convinced himself everything would be OK. On final approach, the plane glitched bad an basically spun into the ground.
Disgusted, he vowed that he had learned his lesson and tossed the receiver in the trash. Miraculously, he was able to rebuild the plane but it will never be quite the same.
After my Cherokee went in, my Spektrum receiver was in the mail on it's way to Horizon first thing on the Monday after. I'd rather play it safe. If the repair cost is too high, I will scrap it and get a brand new receiver.
panzerd18 06-21-2008 07:07 PM
RE: Did I stall???
If you do not know what a stall is why don't you Google it, there is heaps of information. Like this http://en.wikipedia.org/wiki/Stall_(flight)
kid chuckles 06-21-2008 07:32 PM
RE: Did I stall???
A stall is when your plane falls out of the sky from just plain going to slow. If it weighs 5lbs. thats alot to keep from just falling because of gravity. When you get to slow gravity takes over and down it goes. Not enough wind over or under the wings to keep 5lbs. floating. EASY. lol. Drop a 5lb plane and see what you would think it takes to keep it from falling. Like the Duke boys jumping a pond. going fast they made it. Going slow half way and fall into pond. Slow down to muvh you will Stall.
Campgens I did the very same thing the other day with a Frenzy. Just was flying slow into the wind and turned and never throttled up. Brain dead and knew better.
Jetdesign 06-21-2008 07:35 PM
RE: Did I stall???
I'm starting to think it was a stall, too. I had low power and was using a decent amount of elevator into base. I can't remember all that clearly, but I think I might have been turning too hard with the ailerons, and using more and more elevator to complete the turn. The bit above about the control surfaces actually worsening the stall makes a lot of sense, and this could have been exactly what happened. It seemed like what I would expect a hit to feel like; I lost total control of the plane, and it seemed to be flying on its own. What I am guessing happened is that it was in a bad stall, but the forgiving nature of the plane allowed it to mush into a position to gain some airspeed, which made it seem like it was still flying. Since the plane was getting far away, and flying away from me, there was a bit of a lag before the throttle input was received, the engine sped up, and the prop got enough RPM's to actually start flying.
I'm actually hoping it was a stall (both times!) so that I can feel safe flying over that spot again. The president, treasurer, and safety officer of my club all checked out my plane and receiver, and all gave me the go ahead to fly it after my crashes. We have A LOT of unoccupied real estate (big farm) and I was flying it up to great distances with no problems. The only times I had a problem were turning in to final at low power.
I thought I knew what a stall was; didn't realize they could get so drastic!
ChuckW 06-21-2008 08:35 PM
RE: Did I stall???
ORIGINAL: gaRCfield
Doing a range check cannot always determine a receiver is OK after a crash. Vibration, temperature and other factors can reveal damage to the internal components. This could easily be missed during a simple range check. It may even be fine "most of the time when flying". When all of the conditions are right though... bad stuff happens.
The ONLY way to determine if a receiver is OK after a crash is for a qualified technician with the proper equipment to disassemble, inspect and test it. Unless your club president, treasurer and safety officer are trained and have access to this stuff, they should have recommended that you send your receiver in. I'm sure they are good guys and great pilots but I'm sorry... I think they gave you bad advice. I'm not trying to be harsh or mean but that is my honest assessment.
I would be VERY suspect of your receiver. It has been through 3 crashes, two of them pretty violent based on your descriptions.
RC flying is inherently risky. There is a chance we'll mess up as pilots, a chance good parts or structures will fail, a chance for radio interference and whole bunch of other stuff. We must make sure to minimize the chance of things going wrong.
I'm not saying that I know for sure your radio receiver is a problem. I will say that you need to be suspicious of it though and don't trust it until you know for certain that it is certified as OK.
Jetdesign 06-22-2008 12:34 AM
RE: Did I stall???
Chuck, I believe what you are saying. I was talking about sending in my receiver, and literally EVERYONE at my club told me I was nuts to do so. I heard everything from "just do a really thorough range check" to "90% of the time it's just the crystal" (I got a new crystal) to "receivers are pretty tough." So it was easy for me to take the easy road and just range check the receiver several times. I'll have it checked out though, there's a link around here somewhere for $15.00, so I'll find it and have it checked.
But like you said, when the conditions are right...
I'm really having a tough time getting the plane to come in slow. Two clicks above idle and the plane is a pile of mush, needing lots of rudder and plummeting down out of the sky. 3 clicks above idle and my instructors are telling me that I need to work on coming in slower (don't understand what's wrong with faster landings though:eek:). So I was trying to practice coming in as slow as physically possible.
combatpigg 06-22-2008 12:52 AM
RE: Did I stall???
Isn't the Dolphin the one that everyone is raving about being a great 2nd plane?
Allfat 06-22-2008 12:53 AM
RE: Did I stall???
Yeah, it is a copy of the Sig 4*
Jetdesign 06-22-2008 12:59 AM
RE: Did I stall???
Yep. I still love the plane, don't think this means it's not a great second plane. Although it's all I know. It just seems to like to go fast.
combatpigg 06-22-2008 01:07 AM
RE: Did I stall???
A good flying .40 powered plane in this size range should weigh no more than 4 pounds for great all around handling. The RC pilot shouldn't feel like he is balancing a balloon on a stick when he slows his plane down. I agree with the advice to have a crashed RX checked out. The most expensive way to do this hobby is to try to do it cheaply, paying upfront for a RX checkout is cheap insurance.
Jetdesign 06-22-2008 01:20 AM
RE: Did I stall???
Hmm, maybe it's too heavy? I added after market landing gear, but definitely not a pound of additional weight. And axles and a small strip of ply, and lots of epoxy. For repairs I added 4 small sticks of balsa, 2 medium sticks, and glue. Removed the pilot in the canopy, which probably weighed as much as all the balsa I added.
Should I weigh my plane? Loaded with gear and engine?
Nathan King 06-22-2008 07:58 AM
RE: Did I stall???
ORIGINAL: gaRCfield
HA! No way it's too heavy. I currently have a scale model in my hangar whose wing loading comes out to 43 oz/ft^2 and it flies fine (if you fly on the wing and don't have an engine quit :) ).
Do you need to send in the receiver? Well, that depends on how much risk you are willing to accept. I always like to mitigate my risk as much as possible, so I would send it in. Since I fly some pretty expensive stuff I always send in my transmitter during the winter for a checkup as well. That's probably overkill for anyone besides an anal retentive nut though. :)
Jetdesign 06-22-2008 10:05 AM
RE: Did I stall???
What I meant to ask is if I added too much weight to mess with it's trainer characteristics.
ChuckW 06-22-2008 12:00 PM
RE: Did I stall???
ORIGINAL: gaRCfield
I seriously doubt the plane is too heavy. If the advertised specs are correct, then the Dolphin has a wing area and overall wing loaded right in between that of a Sig 4-star and a Goldberg Tiger-2. It should slow down and land very nice. Even the addition of different gear, glue from repairs and other stuff shouldn't hurt it too bad.
The GP Cherokee has a little less wing area and weighs more but it still lands nice, easy and pretty slow. Heck, My kit built GP Super Sportster 60 is a porker compared to modern ARF's. It has a wing area not much bigger than the Dolphin but weighs considerably more. It still has great low speed characteristics and lands nicely.
What is your plane doing at low speed? Nose dropping rapidly? Nose up (ballooning)? You may have a CG problem. Start with what the manual says but don't trust it. The technical information that comes with the no-name ARF's is very suspect. It should glide in at idle just fine unless you have a really strong headwind.
Jetdesign 06-22-2008 12:56 PM
RE: Did I stall???
I'll check the CG again. My instructor had me balance it so that it requires about 1/4 to 1/3 down elevator to fly inverted. At idle speed it doesn't really do anything funny other than not fly. It takes a lot of elevator to keep it in the air, and still descends rapidly. From what I recall, flying downwind leg (with no wind) at two clicks above idle (just to see what was happening) needed a bunch of elevator, and the plane was a bit nose up. Roll rate was very slow and mushy, and I had to be careful to keep the plane level. But this is exactly what I had expected.
Sorry if I'm not clear enough about stuff, I'm still learning this plane (20 flights?) What was happening was that I was coming in 3 or 4 clicks above idle. I didn't think there was any problem until the club president told me I need to learn how to land it slower. Anyway I'd come in at 3 or 4 clicks above idle, and hit idle when I wanted to set it down, and it would set right down, but definitely needed some room on the ground to slow down. Now that I think about it I guess I did have a hard time in that I had to take a few approaches so as not to overshoot the runway. So I was told to learn the descent rate, which is why I've been flying as slow as I can, to try to learn the planes behavior at low throttle. Felt like I was getting it until this whole stall/hit episode happened. I had a bunch of landings, with a decent descent rate, plopping the plane on the ground in the first 1/4 runway, and it stopping within 20 feet or so. But just when I got to the point of doing that comfortably my plane went wild on me.
This is what made me think I was hit. I flew a bunch of touch-and-go flights, with enough speed for take-off, then right back down to a couple of clicks above idle, and flew the pattern just fast enough to stay airborne. I felt very comfortable controlling the plane, as it was predictable - it did exactly what I expected it to do at such low power settings. I don't recall feeling any wind gust, especially something to cause a change in the plane's attitude, but maybe it doesn't take much, or maybe it was up high enough for me not to feel it. Regardless, the plane became unpredictable and completely out of control.
My idle is just fast enough to keep the engine from stalling, which I assume is correct. There is quite a noticeable jump in RPM between each click. I'm flying with an 11x5 mas prop.
On the receiver issue, I understand I should have it checked. Is there a need to check the servos, too, or is that something I or someone at the club can do?
ChuckW 06-22-2008 01:27 PM
RE: Did I stall???
On your approach, keep the nose down slightly to maintain airspeed and keep the wing flying. On a calm day or in very light winds you should be able to do this at idle. On windy days you may need to carry a little throttle depending on the plane. Rotate the plane to level a few feet off the ground and GENTLY feed in up elevator as needed to keep it level until it touches down. To avoid it bouncing back up, release the elevator just before the wheels touch. It will roll out on the mains for a ways then drop the tail. Then hold up elevator to keep the tail planted and taxi back to you.
Idle speed should be a nice smooth RPM with no indication of the engine quitting. It shouldn't be so high though that the plane starts rolling away at idle. I fly off of pavement and I like my planes to sit still at idle or roll forward slowly. The type of prop has a lot to do with this too. Some make a lot of thrust at low speed and keeping the plane still may be impossible. Your 11x5 should be perfect for the engine and plane though. You should have a nice, reliable idle.
Should you have servos checked out? I say no, at least for most sport servos. It is easy to determine if you physically damaged or stripped a servo though. The only thing you can't detect it damage to the electronics. If there is really any doubt about a servo, just buy a new one. Paying postage and labor to have it checked will cost much more than most new standard sport servos. Receivers are a different story... checking them out (or replacing them) is mandatory.
ErikElvis 06-22-2008 02:19 PM
RE: Did I stall???
I stalled the minnow one time coming in or a landing. I chopped the throttle and was trying to float it in from to far out. Got down to about 10 or 15 feet off the ground and no control surfaces were responding. It was drifting down and towards a pavilion. I just gave her full throttle and then was able to turn it to open field and get back up in the air. That was the first time I experienced that. I makke sure I keep the airspeed up a lil now when coming in.
n19htmare 06-22-2008 05:31 PM
RE: Did I stall???
i usually land my 4* with no throttle. I also have the plane trimmed to fly pretty much hands free. When there is no wind, it flies steady and straight with no hands.
http://www.youtube.com/watch?v=VpXWc0pAayI here's a video.... sorry the cameraman couldn't keep the camera steady.... you can see how I usually land.
