RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Can crank cases rust??? (https://www.rcuniverse.com/forum/beginners-85/7680448-can-crank-cases-rust.html)
Jetdesign 06-30-2008 10:55 PM
I thought the crank cases were aluminum, but I've got some brown stuff 'growing' on the outside of my crank case: on the top around the glow plug and cooling fins, and on surface where the muffler bolts on (and on the muffler too). Or is this just dirt and stuff that got cooked on there?
I don't want my baby to rust!!!
bigedmustafa 06-30-2008 11:00 PM
RE: Can crank cases rust???
It's fuel varnish, it brushes off using a brass-bristled cleaning brush.
Nathan King 06-30-2008 11:02 PM
Ditto on the varnish. It's nothing to worry about and can be cleaned with a little investment in time.
OzMo 06-30-2008 11:05 PM
NO [&:] But the steel crank and steel ball bearings sure can and do rust if stored poorly. After run oil is also known as Marvel Mystery oil.
After a day flying run the engine out of gas and pull the fuel line and restart to clear as much fuel from the engine as possible. A few drops of Marvel Mystery oil down the throat of the carb and flip it several times to disperse it inside the engine and your good until time to fly again. For winter storing be more generous and also add a couple drops in the glow plug hole as well. A well cared for glow engine should last for decades.
Sourkraut 06-30-2008 11:11 PM
The brown discoloring on the exterior is burnt on NITRO SNOT ( varnish). It cleans right off with a little anifreeze soak and bath.
Curt
Jetdesign 06-30-2008 11:35 PM
Awesome! Thanks guys. I'm sure the inside of my engine is GLEAMING as I take very, very good care of it (run it dry, plenty of after run, etc.).
This makes me happy:D
ChuckW 07-01-2008 12:25 AM
Run fuel with synthetic oil instead of castor and you won't get varnish.
Jetdesign 07-01-2008 12:28 AM
ORIGINAL: ChuckW
I knew someone was going to say that!;)
ChuckW 07-01-2008 12:33 AM
Yep, castor smells really cool but it can be messy.
Jetdesign 07-01-2008 12:52 AM
Well the smell (and the protection:)) might be worth a bit of cleaning here and there. What else am I going to do over the winter (if I'm not building a kit that is)?
jetmech05 07-01-2008 04:57 AM
When aluminum corrodes it leaves a white powdery residue.....
Good Flyin
Rodney 07-01-2008 05:55 AM
ORIGINAL: OzMo
While Marvel Mystery Oil is slightly better than nothing, it is not a good afterrun oil. Any air tool oil (including Marvel Mystery Air Tool Oil) and ATF is much better as an after run oil. Just a few drops in not enough, you need to have enough to coat the bearings and; if a 4 stroke, you must put it into the crankcase (putting it the exhaust or vernturi does little good in a 4 stroke).
rwright142 07-01-2008 06:49 AM
ORIGINAL: gaRCfield
As others have noted, it's the residue left from the glow fuel after burning.
I used Dawn Power Dissolver to remove it from a muffler and posted my results here: [link=http://www.rcuniverse.com/forum/fb.asp?m=5929584]Removing Glow Fuel Residue[/link]
Gray Beard 07-01-2008 04:27 PM
Not all engines can take after run oil. Use it in A YS and you will be replacing parts.
Living in very dry areas I never use the stuff except when I'm rebuilding or working on an engine. Come winter months I do run them out of fuel but my storage time is almost nothing.
