10c FUTABA
Hi guys. I have a Futaba 6eax 2.4 and 3 receivers, 2 606 and 1 617 and I was wondering would the Futaba 10c "which I plan on buying" be compatible with these receivers . Also I like the 6eax but one thing that annoys me is that they never put a timer on the radio which would be very handy. Thanks in advance.
RE: 10c FUTABA
The receivers will be compatable with the 10C. If all you feel you are missing is a timer though... that is an awful expensive timer. I have been flying a 6eax for about 3 years now (72 Mghz) and decided I needed at least 7 channels for dual elevator servos without a reversing Y-harness. I ended up going with the JR 9309 2.4 Ghz as I was not happy with the computer interface of Futaba. Since you already have 2.4 Ghz receivers for Futaba the 10C may be your best choice.
RE: 10c FUTABA
"If all you feel you are missing is a timer though... that is an awful expensive timer."
Yes, but you get three timers on the 10c :D You can use the 606, 607, and 617 receivers with no problem. |
RE: 10c FUTABA
http://2.4gigahertz.com/receivers/index.html
As you can see here, the 10C will work with any Futaba 2.4 RX from the 606 and above. |
| All times are GMT -8. The time now is 04:42 PM. |
