RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Radio Help (https://www.rcuniverse.com/forum/beginners-85/7829752-radio-help.html)
runt_71459 08-10-2008 11:27 AM
Radio Help
I fly with JR equipment, tx,rx and servos, all on chn 40. What is the deal with trying to find a crystal? Every place I look online and LHS withen 200 miles are sold out of the crystal. I looked on Horizan Hobby today and they said the crystal was out of production. I would have posted this on the JR forum but its closed. Can I buy that spektrum radio modual to my JR 600 radio so I dont have to worry about freqs?
nobodytwo 08-10-2008 11:56 AM
RE: Radio Help
Runt:
Sorry about the channel 40 problem, don't have any information on that situation. But I can tell you that the JR600 is not convertible to 2.4. [&o]
Happy Landings!
carrellh 08-10-2008 12:08 PM
RE: Radio Help
1 Attachment(s)
Exactly what crystal do you need?
Channel 40 is 72.590 mhz. I searched Horizon for 72.590 under JR radio parts
http://searchrc.horizonhobby.com/ind...demandrank%7c1
They have 4 items listed as available to order
FM Receiver Crystal
FM Crystal Set
FM Transmitter Crystal
FM Dual Conversion Receiver Crystal
To answer the question about using a Spektrum module in your transmitter, you need to list the exact transmitter that you have.
If the transmitter has a large removeable frequency module in the back, you probably can do it.
If it has a regular crystal in the back, or front, you cannot use a Spektrum module in it.
runt_71459 08-10-2008 12:19 PM
RE: Radio Help
I was trying to put a Hitec 5 chn RX in a foam plane. The RX takes a single conversion crystal that is what I can not find. Maybe I will start to consider getting a spektum!
JohnBuckner 08-10-2008 01:43 PM
RE: Radio Help
http://servocity.com/html/fm_am_sing...on_air__6.html
aerowoof 08-10-2008 07:19 PM
RE: Radio Help
if it's a hi tec rx you should be looking for a hi tec crystal
carrellh 08-11-2008 10:05 PM
RE: Radio Help
ORIGINAL: runt_71459
That's totally different. I searched for JR cryatals. You need a Hitec crystal for your Hitec receiver. www.radicalrc.com is one source
JohnBuckner 08-11-2008 11:52 PM
RE: Radio Help
The direct link in post #5 is the proper Hitec Crystal and ch 40 is avaliable 7.95.
