RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Telemaster 40 Rates? (https://www.rcuniverse.com/forum/beginners-85/7850734-telemaster-40-rates.html)
cowboychris244 08-15-2008 09:10 PM
I have built a Telemaster 40 and am powering it with an OS 46AX. Any suggestion on the rates for aileron, elevator, and rudder. Also, any recommendations on a prop size. The build directions don't give me any guidance in these areas. Thanks for your help.
Alex7403 08-15-2008 09:18 PM
RE: Telemaster 40 Rates?
From my experience the 46 AX likes best 11x5 and 11x6 props, other sizes work well too.
it also turns 11x7 but i think it was too fast, no need for a slow airplane.
Alex
TedMo 08-16-2008 07:12 PM
Since you ask about rates I have to assume you're referring to dual rates? Otherwise perhaps you mean amount of throw,travel adjustment. If it's dual rates you're asking that is not a critical adjustment and can only be set bye guessing and flying. The total travel is generally given on the plans. This is a very gentle aircraft and if you don't feel capable of maiden flight let someone that is do so and any adjustments will be evident.
