RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Fuel Valve question (https://www.rcuniverse.com/forum/beginners-85/7880163-fuel-valve-question.html)
capt17 08-24-2008 12:32 PM
Fuel Valve question
For some reason I misplaced the diagram on how my valve goes into the fuel system. Mainly what are the the two outlets going to? Thanks for the help!
w8ye 08-24-2008 03:20 PM
RE: Fuel Valve question
If you are asking about a quick fueler valve you can analyze it yourself
Without the probe inserted find the path you can blow through
With the probe inserted find the path of airflow when you blow in the probe
When you blow in the probe - the outlet goes to the tank. The outlet that nothing comes out when you blow through the probe is the one that goes to the engine.
jetmech05 08-24-2008 04:53 PM
Is this an older valve? if so just use a 3 line system as fuel valves tend to leak, causing engine problems......the fuel valve will be the last thing you think of when troubleshooting...except now that you read this post
Good Flyin
capt17 08-24-2008 06:31 PM
Thanks all! It's brand new so I'll be ok!
jetmech05 08-24-2008 09:35 PM
I've never used a valve because as a noob I asked the ace of the base about valves he told me they will leak sooner or later...all the wing men shook their heads in agreement....I've always used a 3 line system and I've never had a problem...
the subject of valves comes up here once in a while...they do leak
Good Flyin
JohnW 08-25-2008 09:50 AM
Ditto, valve bad, fuel dot good.
