RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Setting correct surface throws (https://www.rcuniverse.com/forum/beginners-85/7912166-setting-correct-surface-throws.html)
brett65 09-02-2008 01:18 PM
I borrowed a H9 digital meter that only reads degrees, my manual gives only mm. I can convert to inches no problem, but can the degrees be used to set it without having manufacturer degree specs? Do I need to get one of these instead?
http://www3.towerhobbies.com/cgi-bin...?&I=LXK260&P=M
http://www3.towerhobbies.com/cgi-bin...?&I=LXET68&P=7
Red B. 09-02-2008 01:22 PM
RE: Setting correct surface throws
Some patience and a simple ruler will get the job done.
MinnFlyer 09-02-2008 01:23 PM
You don't need anything fancy.
I use the TLAR Principle (That Looks About Right)
Remember that the manufacturer's recommendations are only that - Recommendations.
Set the throws so they look about right, fly the plane, and adjust accordingly.
brett65 09-02-2008 01:40 PM
Ok, that sounds simple enough.
Gray Beard 09-02-2008 05:45 PM
I have only gone by degrees for years now, I make up my own meters. For A 3-D plane I start at 18 degrees high and 12 degrees low rates, all other planes at about 10 or 12 high and 8 or 10 for the low. At the same time I use Minns TLAR method, sometimes it and the meters work hand in hand. The meters will get you dead on though.:D;)
Charlie P. 09-02-2008 09:43 PM
Sure. If you'd paid attention in 10th grade trigonometry you'd know the angle/degrees and the length of the control surface (adjacent) would be used to identify the movement (the opposite leg to the angle).
Now, if we can find someone who paid attention he'll tell you the details.
I do remember Vicky Eldermann's sweater, though . . .
Redback 09-02-2008 09:54 PM
Measuring throw in inches, millimetres, or miles for that matter varies depending on the width of the control surface at the point of measurement. Half an inch of travel will be different for different size aircraft.
A measurement in degrees however is the same irrespective of the plane, which is why the meter is graduated that way.
The magic formula is Sine A = D/W, where:-
Sine A is the Sine (trig function) of the deflection angle
D is the deflection
W is the width of the control surface at the point of measurement.
Or, as someone has already said, you could just guess:D
Terry
Spacemonkey71 09-02-2008 10:40 PM
just remember ONE thing after you set your "low" and "high" settings:
WHICH SWITCH IS "LOW" AND WHICH IS "HIGH" :D
you can give yourself a cardiac arrest if you get these 2 mixed up; I just make it a part of "pre-flight" checking now ;)
....tell me there isn't SOMEONE here who hasn't done this at LEAST ONCE !!!!! [:@]
Gray Beard 09-02-2008 11:54 PM
Unless I set up my throws on A three way switch the rate switches are always the same if left on factory default, rate switches are never A problem, remembering what switches I have set to do other stuff??? That has jumped up and bit me in the mule!!!:)
Redback, why don't you just lay back, close your eyes and remember Vicky Eldermann's sweater?? :eek:
MinnFlyer 09-03-2008 08:18 AM
If you guys are intereested in getting it perfect, whether by degrees, inches or millimeters, I just reviewed a new product that is the cat's meow.
http://www.rcuniverse.com/magazine/a...rticle_id=1030
Ah yes, Vicky Eldermann's sweater! I remember Vicky went to Lincoln High School where she was once voted "Miss Lincoln"
...Because everyone took a shot at her in the balcony :D
jetmech05 09-03-2008 12:09 PM
what the heck did redback say?
Campgems 09-03-2008 10:57 PM
ORIGINAL: jetmech05
I think it was something about Vicke's sweater.
brett65 09-03-2008 11:54 PM
ORIGINAL: Redback
D is the deflection
Terry
You know, I got an A in trig in college, but I haven't used it since so...[:-]
TexasAirBoss 09-04-2008 01:56 PM
I believe the most accurate measurements are actually taken using satellites. :D
Initial set up is used with a ruler and the instruction's recommended throws. Then you fly. Then you make tiny adjustments using your Xmitter until the plane performs and feels the way you like. That changes from person to person. Your throws will be different from everyone elses. So excrutiatingly accurate initial values are not needed.
