Y LEADS
Hi As a beginner what does a Y lead do on eilarons if one side goes up and the other side down and there is one lead coming from the RX how does it work :eek:
RE: Y LEADS
The Y connector allows you to run dual servos off the same RX channel.
If its dual aileron servo setup out on the wing the linkage is setup such that the pushrods are attached to the control horn on the opposite side of the other servo. That way the movement is made in the opposite direction with one aileron going up while other goes down. Hope that helps. |
RE: Y LEADS
Simply put the Y is simply a splitter.
Both servos move in the same direction (ie... clockwise or counter clockwise) but since the mechanical connection to each servo is on opposite sides of the servo the ailerons themselfs will move opposite of each other. You can hook up flaps with a Y if both mechanical links are on the same side of each servo so that both flaps will move in the same direction. |
RE: Y LEADS
1 Attachment(s)
Here's a visual of what Missileman is saying
RE: Y LEADS
Hey MinnFlyer and RCKen where do you get all those nice diagrams? My post are always so plain.
RE: Y LEADS
ORIGINAL: goirish Hey MinnFlyer and RCKen where do you get all those nice diagrams? My post are always so plain. |
RE: Y LEADS
ORIGINAL: Deadeye ORIGINAL: goirish Hey MinnFlyer and RCKen where do you get all those nice diagrams? My post are always so plain. ;) Ken |
RE: Y LEADS
Yes, I draw them, and Ken gets all the credit for posting them [:@] :D
RE: Y LEADS
ORIGINAL: MinnFlyer Yes, I draw them, and Ken gets all the credit for posting them [:@] :D ken |
RE: Y LEADS
ORIGINAL: RCKen ORIGINAL: MinnFlyer Yes, I draw them, and Ken gets all the credit for posting them [:@] :D ken |
RE: Y LEADS
Thanks I undestand Now:)
RE: Y LEADS
Thank it does help cheers
RE: Y LEADS
To every one who answered my question thank's Chewit;)
RE: Y LEADS
Glad we could help!
| All times are GMT -8. The time now is 04:18 PM. |
