RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   OS Max 40 FP question (https://www.rcuniverse.com/forum/beginners-85/8139479-os-max-40-fp-question.html)
blhollo2 11-12-2008 08:32 AM
Hello all, I just bought a never used OS Max 40 FP engine, but I am having problems finding the specs and reviews on it and how much Horsepower it produces...Anyone know the specs on the little engine? Also what is the best prop to swing for a warbird?
crossman 11-12-2008 08:42 AM
RE: OS Max 40 FP question
The 40 FP was rated at about 1 HP It handles a 10x6 prop farily well. I may still have the instruction sheet to mine. If so, I can probably scan it for. That was a pretty durable engine if treated well. Mine is at least 12 years old.
Chuck
jeffie8696 11-12-2008 10:00 AM
The Fp and LA are very similar in operation. the FP has a higher power output due to better ports. They both have plain bearings and if I am not mistaken nickle plated bores. I would say the LA 46 and FP 40 are about the same on power.
bruce88123 11-12-2008 10:23 AM
http://www.osengines.com/parts/xr13331.html Part list if you ever need it.
DavidAgar 11-12-2008 04:20 PM
The FP seris of engines are one of the best that OS ever made. They are not a power house, but never miss. I still have a great number of 40 and 60 FP engines and they just keep running. Kinda like the Energizer Bunny. Good Luck, Dave
MikeL 11-13-2008 12:42 AM
Remember the old magazine ads for the 40FP? The French-Canadian guy, telling the story about how he lost his engine in the fall, then found it the next spring? Standing there with the little FP in a chunk of ice... fun stuff!
It'd have to be a pretty tiny warbird for a 40FP. They're not revvers, but will turn a slightly larger prop than a ball-bearing 40.
crossman 11-13-2008 08:54 AM
blhollo2,
I found the manual that came with mine. Actually, it is just a large sheet double sided. I have it scanned to a pdf file. If you send your e-mail address, I can forward it to you.
Chuck
flyinrog 11-13-2008 10:05 AM
Hey blh, the 40FP is a great engine, dont think I've ever heard a bad thing about one...What part of NC are you in?..Raindave over in the 1/2a forums is a local engine guru and probably has all the data you want, mine powered a goldberg eagle 2 pretty well, I'm guessin yours is in about a .25 warbird....Rog
bruce88123 11-13-2008 10:18 AM
ORIGINAL: crossman
blhollo2,
Chuck
Click his email link at the bottom of his post and attach it. I think you can do that, never tried.
Murdoc 11-13-2008 10:55 AM
I had a 40 fp a few years back. It"s still to date one of the best ongines I"ve owned!:D
crossman 11-13-2008 12:14 PM
ORIGINAL: bruce88123
ORIGINAL: crossman
blhollo2,
Chuck
I just tried that, There's no place to attach the file. I guess I have to wait for him to post again. It sounded like a good idea anyway.
Chuck
blhollo2 11-13-2008 04:23 PM
hey crossman, i just sent you a PM, with my email.. I have the .40 powering my P-40 warbird
crossman 11-13-2008 04:33 PM
I have sent the manual
Chuck
flybug 11-13-2008 04:35 PM
My .40 FP engine is older than the hinges of Narnia and has survived a number of crashes and it is still ticking starting on the first flip. The only thing I've ever done to it is a good cleaning once in a while and kept it well lubricated and bagged when not in use. I tell you it is currently dragging a DuraPlane trainer all over the sky. In short a very durable and reliable engine.
donbue 11-14-2008 10:44 PM
I have a 12 year old FP40 that sat on the motor mount of my never used trainer for all those years hanging from the floor joists. Never ran it. I put some 12 year old (opened to smell it when new) 10% fuel in it and it started right up. My instructor thought the engine was 'abused' but we puttered along with my training anyway. When the 10% was gone I bought a gallon of fresh 15% and wow....what an amazing difference. I had to learn how to fly it all over again. The thought that the engine had been abused is long gone now. That second gallon is about 3/4 gone and I hope to finish it off this year. By the way, I was signed off after 8 sessions of about 4 flights each and the plane survived nicely, it's an old Hangar 9 Easy Fly 40. I owe my success and the plane's longevity to my instructor. Thanks again Fran.
Don
blhollo2 11-15-2008 10:53 AM
I wonder if you can run 30% nitro in it??
flyinrog 11-15-2008 12:48 PM
You can, but it doesnt need it,,most .40's need 5-10% nitro as I understand it..some just figure the more nitro the better, I use %35 in my 1/2A stuff and 10% in everything else.../Rog
JollyPopper 11-15-2008 12:51 PM
Why would you want to run 30%?
blhollo2 11-15-2008 03:54 PM
why? more horsepower and speed!
MikeL 11-15-2008 04:09 PM
For what you'll spend on that kind of fuel, why not get an engine that will provide more power on much less expensive fuel? A 40FP is never going to be a powerful engine, and it may not run very well on 30% nitro fuel.
jcervantes11 12-11-2008 07:24 PM
can u send me the manual please? [email protected]
jcervantes11 12-11-2008 07:35 PM
1 Attachment(s)
Bumber I messed around with the wrong screw, do you guys know the settings for this and what is it for?
w8ye 12-11-2008 09:01 PM
That is the idle air bleed mixture adjustment
The screw goes half way across the hole on the front of the carb for an intial factory adjustment
Typically the screw is screwed out a little ways from this point for best idle
crossman 12-12-2008 09:29 AM
ORIGINAL: jcervantes11
Jim,
I e-mailed you the manual this morning.
Chuck R
hogflyer 12-12-2008 11:27 AM
ORIGINAL: JollyPopper
1/2A engines require a much higher nitro content to run properly. If you run low nitro (15%) they just don't like to run. Remember you are talking about engines with displacements of .049, .051, .061, .074, etc. For .10 - .15, I prefer to run 15% nitro, and above that it depends on the engine. My Super Tiger GS 40 is very happy on 10% while my OS .46 AX and TT .46 Pro run better on 15%. My FP .40 and LA .40 don't seem to care if they run on 10% or 15%, they just keep purring away.
jcervantes11,
When you set the idle needle 1/2 way through the bleed air hole, very seldom do you need to change that setting. My FP's have never been touched and they transition without hesitation. Even with weather changes I don't have to change them, just the high-speed needle.
Hogflyer
