Jr XP6102 HELP!!
I am helping a club member set up a JR XP6102 and I was wondering how to clear all the memory and set it back to default.
Please help! Thanks rc-plane _____________________________ |
RE: Jr XP6102 HELP!!
It has been several years since I had a 6102 so my best advise is to read manual. I do believe you will find as a selection data reset and that's where you should go. However, each model has to be named and all throws set etc. so that's ultimately what you will need to do.If you don't have a manual you will need one. Perhaps Horizon Hobby can help there?
Here you go!
[link=http://www.robotmarketplace.com/images/jrp6644-manual.pdf]Click me for Manual![/link] With most JR radios you can "clear" the configuration for one of the plane/heli/glider "slots"... In effect this sets that "slot" back to the system defaults, but it will NOT clear the name of the plane. e.g. if slot two reads "Twist 40", then after you clear that slot, it will still read "Twist 40" but the values will be back to the factory settings for that plane slot. |
| All times are GMT -8. The time now is 09:28 PM. |
