Flycamone2 trouble!! please help!!
hi i just bought a flycamone2 and are having real trouble , it says in the booklet vidio recording (UP) it is like a p with a little line underneath so i go on that then i press the shutter button to activate it and the 2 little lines go round the square, but then it says mf meaning not enough memory or something like that, but i have a 2 gb sd card! anything i do doesnt work, can someone help me!!!
thanks - super-cub-boi |
RE: Flycamone2 trouble!! please help!!
I read your message 3 times and could not understand what you are refering to.
I have a FlyCamOne model 2 as well.. I found out you need to have the high speed SD card. Not the regular speed one. When I first tried mine, I didn't get anything to work either.
Once I spent the money on the higher speed card, it worked... |
so i high speed sd card u recon?
ORIGINAL: Super-Cub-boi hi i just bought a flycamone2 and are having real trouble , it says in the booklet vidio recording (UP) it is like a p with a little line underneath so i go on that then i press the shutter button to activate it and the 2 little lines go round the square, but then it says mf meaning not enough memory or something like that, but i have a 2 gb sd card! anything i do doesnt work, can someone help me!!! thanks - super-cub-boi The FlyCamOne2 works fine with standard SD cards, High speed ones are not required. However certain 2gig cards can be problematic because of the way the high bit is selected.. You may have an SD card which may not work... Plug the FlyCamOne2 into your computer after downloading and installing the latest drivers from their web site. Update the firmware to the latest following the instructions on the web site. Once done insert your card into the camera and hook it up to your computer. The computer should see the FlyCamone2 AND the SD card ( it shows up as a folder window ). Plug the SD card into a media bay, and make sure that it is formatted for FAT32. |
Also make sure that the card is NOT "Write Protected".
The switch on the SD card may be preventing the camera from writing to it. However just to be sure format the card on your computer first! |
i see well this card is play.coms own and it is in an adapter, my brother had problems getting the pc to recognise it and my printer with an sd port doesnt eather
so dou urecon i should get a new one then? if o can u hgive me a link to a reasonably priced 2-4 gb sd card? ok thanks alot - Super-Cub-boi |
Well I know these work as I've used them w/o problems.
[link=http://www.newegg.com/Product/Product.aspx?Item=N82E16820180627]SanDisk Cards[/link] As cheap as that is, there are others there for $5.99 or so on that web site. e.g. [link=http://www.newegg.com/Product/Product.aspx?Item=N82E16820141030]Cheaper![/link] I've used the latter on cameras, but I have not tried it on the FlyCamone2. |
im from the uk but i have found that on another site for £4
so i might buy that thanks - Super-Cub-boi |
h,i I've had the flyonecam2 for 6 months now, and it has worked great but now it says MF usually that would mean memory full but there is nothing on the 1GB card. Please help ASAP<div>-austin</div>
Hi Again<div>
</div><div>It works again, I just had to wipe the memory card. I plan on putting on my Sig Four Star. Any mounting tips?</div><div>-austin</div> |
| All times are GMT -8. The time now is 07:50 AM. |
