RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   too cold? (https://www.rcuniverse.com/forum/beginners-85/8322501-too-cold.html)
thorn247 01-05-2009 05:46 PM
too cold?
how cold does it have to be to affect lipos and radios. I charged the batteries, and thru the plane in the car, when i got to the field it would not connect.
I came home tried in my basement. conected but had choppy movements? about five mins later everything was moving fine. its only -2c or 28f. I have a
72mhz radio
richg99 01-05-2009 05:59 PM
RE: too cold?
Anything electrical may be affected by cold. Some devices/connections shrink and pull away.( ESC; Servo connectors; etc. ) Might not have been the battery...might have been a connector. Though, I've read here about keeping the battery in one's pocket to keep it warm, before installing. Rich
thorn247 01-05-2009 06:02 PM
RE: too cold?
thanks
ChuckW 01-05-2009 08:36 PM
RE: too cold?
I've had lipos that would not work well in the mid 30's (F). They'd work but not deliver good current. I warmed them up in the truck and they started working well. It is obviously a heck of lot colder up there in Canada so I can see how lipos would perform even worse.
Charlie P. 01-06-2009 01:57 PM
RE: too cold?
1 Attachment(s)
I have had radios out for hours in temperature in the teens (ºF). The flight batteries (NiCad & NiMH) do have a tendency to loose "oomph" faster, but I believe some of that may be due to trying to move stiffer servos and control surfaces.
Don't know about the electric power aspects.
cruzomatic 01-06-2009 03:42 PM
RE: too cold?
Hey, what's that white stuff all around you on the ground?? :D
drZoidBeRg365 01-06-2009 09:35 PM
RE: too cold?
My plane an electric apprentice flew great while it was the mid 30`s outside, me? Well, I learned that gloves and TX`s don`t mix, that and I learned that if you going flying in mid 30`s weather dress warm!
LuftwaffeOberst 01-07-2009 08:00 AM
RE: too cold?
I haven't had much of a problem with the electronics... but I've had problems getting my 2-stroke started. I had to put a few drops of glow in the glow plug hole to prime the engine... make sure you use a "Chicken Stick" or electic hand starter, she will kick or re-coil back, it hurts like H&ll if you try to start it by hand. It's best to run the engine a little rich on the high end as well.
