Sanding CA
1 Attachment(s)
I read somewhere that sanding CA is really difficult. And I got a bunch on the fusalage and was wondering if it is going to show through the covering if I cant get it sanded out. Going to try to post a pic
John |
RE: Sanding CA
try sanding and see what your results are
You may have to fill around some of those formers anyway. Just use household plaster spackling |
RE: Sanding CA
As mentioned, fill all your gaps with filler, I use a product called Paint and Patch, from Home Depot, and then sand the side of the fuselage with a bar sander with some 200 grit sand paper. Do not just sand the CA as you will get low spots in the balsa, as the Ca is harder than the balsa. Once you have sanded with your bar sander, you will still see the CA, however when you cover it you should not see it if you are using an opaqe color of covering. Good Luck, Dave
RE: Sanding CA
Don't use thin CA for stuff like that. In fact, I rarely use thin CA for anything except CA Hinges.
Medium CA won't run all over the place like that - and if it does, you're using too much! |
RE: Sanding CA
And now you know why many of us use wood glue also.
RE: Sanding CA
Wood glue is for sissies
:D |
RE: Sanding CA
ORIGINAL: MinnFlyer Wood glue is for sissies :D |
RE: Sanding CA
He already know that :D
RE: Sanding CA
ORIGINAL: bruce88123 ORIGINAL: MinnFlyer Wood glue is for sissies :D Ken |
RE: Sanding CA
You should hear what he calls ME! (He can't say it here cause RCU is a family site)
RE: Sanding CA
ORIGINAL: MinnFlyer You should hear what he calls ME! (He can't say it here cause RCU is a family site) Ken |
RE: Sanding CA
Stop swearing! (See what I mean?)
RE: Sanding CA
I think those jet guys in Florida deserve you two. Have a good trip.:)
RE: Sanding CA
I don't get along with thin CA it gives me sinus trouble for a week afterwards
I use the yellow glue. The last time I went to the store they didn't have any Titebond II. So i bought Borden's. Some of the Borden's got on the fuselage sides where I laminated them together and it was harder than the balsa. |
| All times are GMT -8. The time now is 02:48 PM. |
