RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Engine thrust angle Question (https://www.rcuniverse.com/forum/beginners-85/8376510-engine-thrust-angle-question.html)
FLAPHappy 01-19-2009 03:20 PM
I am putting a Stick 4D together and did not like the rubber engine mount it came with. I changed the engine mount to a Dubro soft mount for a Saito 72. After mounting the engine, it appears the thrust angle is up a tad. How do you figure out what the proper angle should be?
Thanks for your input.
w8ye 01-19-2009 04:17 PM
RE: Engine thrust angle Question
Thrust angles are typically 2 degrees down and 2 degrees right when setting in the cockpit
http://www3.towerhobbies.com/cgi-bin...&I=LXE953&P=ML
Jetdesign 01-19-2009 04:42 PM
http://www.palosrc.com/instructors/trim-chrt.htm
http://aeromonclova.com/Documents/Ajuste_de_Trims.htm
Go here and look at steps 6 and 7. They are for correcting your thrust angles.
ChuckW 01-19-2009 05:13 PM
Also keep in mind that there is always an exception to every rule. I built a Cap-232 kit once that specified a slight up-thrust. That may not be the case on your plane of course. I'd fly it and decide what it needs base don how it behaves.
w8ye 01-19-2009 05:27 PM
I sometimes depends the position of your thrust line
Those sea planes with the engine up on a pod above the wing must have up thrust
