RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   installing servo on wing (https://www.rcuniverse.com/forum/beginners-85/8396189-installing-servo-wing.html)
alexedit 01-24-2009 05:06 PM
ok so I have an alpha 60 and I am trying to install a new servo on the wing and it just doesn't fit. ...it's the same servo it had before.
Any ideas?
CGRetired 01-24-2009 05:34 PM
RE: installing servo on wing
Well, do a little sanding to make it fit, I guess.
CGr
w8ye 01-24-2009 06:42 PM
I sometimes have to trim them out a little with an exacto knife
TedMo 01-24-2009 09:41 PM
If the same servo it must fit. You say same does that mean same manufacturer, like Hitec,Futaba etc? perhaps it's a different model No.that could explain it. Anyway just remove material so it fits. This is model building.
Charlie P. 01-24-2009 10:41 PM
ORIGINAL: alexedit
Any ideas?
Doesn't fit how? Won't go back in the same opening? Usually you have to thread the wires in first (you did tie a messenger string on the old wiring and tape it off so you could thread the new back in?) and get the stress-relief grommet below the cross-members first and then wiggle the case into place. A tight fit is a good thing.
