Lanier Extra 3.25 electic?
I have Extra 3.25 kit and I'm thinking of building it as electric. what kind of engine, esc, battery and servos should I use.
thanks all, MM |
RE: Lanier Extra 3.25 electic?
I'm not familiar with the model, and Tower quit listing thier specs when Lanier closed down.
What's the wingspan, weight, and recommended glow engine? |
Lanier Extra 3.25 specs:
http://www.happyhobby.com/hobb_html/...extra_3_25.htm I found this motor which states it is an especially good match for 4- to 5-pound scale airplanes on the market ... Kadet LT-25, Sig Frazer, Lanier Extra 3.25, Global Tequila Sunrise 25 and others: http://www.e-fliterc.com/Products/De...odID=EFLM4025A You can probably find one cheaper, and I am not sure what size ESC you will need (possibly 50-60 amp) but its a rough idea of the high cost you will endure to convert this plane to electric. EDIT: I have been looking and I found more info here: http://www.hobbyworks.com/default.cf...D=469522&hs=RC Needed to Complete if you purchase this motor: * 40A - 45A Brushless ESC * 3S - 4S Li-Po or 10 - 14 Cell Ni-MH/Ni-Cd * 11x8 to 14x7 Prop These servos would probably be OK http://www3.towerhobbies.com/cgi-bin...&I=LXN676&P=ML Personally I like Futaba http://www3.towerhobbies.com/cgi-bin...&I=LXNCV6&P=ML but any micro servo should be OK Some more recommendations: http://www.rcuniverse.com/product_gu...cfm?kit_id=111 |
1 Attachment(s)
I have a 3 1/2 lb Modeltech Magic that I fly with this motor:
http://www.hobbycity.com/hobbycity/s...idProduct=3887 And this ESC: http://www.hobbycity.com/hobbycity/s...idProduct=2165 And these batteries: http://www.hobbycity.com/hobbycity/s...idProduct=7363 I have been really happy with this setup. The ESC does get warm, but has not failed on me yet. If I were to do it over, I'd spend the extra few bucks for a 60A ESC. It was much cheaper to electrify this plane than I thought it would be. For servos, I usually use Hitech 311's. They have worked great for me and cost $9.99 at my LHS. Good luck |
| All times are GMT -8. The time now is 06:37 AM. |
