Help with prop selection
I have recently completed a C.G. egalet 50, and I put a magnum gp .25 in it. What would be a good prop to start with?
Thanks, Ryan |
I have an old Eaglet 50 I fly every once in awhile with an OS .25...I use a 9x6 prop with good results.
Bob |
9x4, 9x5, 9x5, 10x3, 10x4 would all work. 9x6 is the most "normal", a 9x5 might help if you fly from rough fields or find you could use a bit more climb.
I'd start with the 9x6. |
| All times are GMT -8. The time now is 12:05 AM. |
