RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   now the cowl! (https://www.rcuniverse.com/forum/beginners-85/8439489-now-cowl.html)
joco1 02-04-2009 09:22 PM
now the cowl!
i got everything fixed and fit perfectly (i thought) on my sundowner 50 but after installing the cowl i found it to be too close to the spinner ive got the engine set right to the mark the manuel says, how would you fix this?
ABELL 02-04-2009 09:30 PM
RE: now the cowl!
I had that same problem with CG Edge. I used a piece of lite ply between the firewall and engine mount. I suppose you could use washers too
Charlie P. 02-04-2009 10:02 PM
RE: now the cowl!
Plug the holes in the fuselage/cowl mount blocks with toothpicks & CA. Make a shim of two thicknesses of cereal box cardboard or put two popsicle sticks behind the spinner (one on either side of the prop shaft) and re-drill 1/16" holes in the firewall blocks for the cowl attachments.
I don't specifically know how the Sundowner cowl is attached, but you get the drill.
I would NOT change the engine to suit the cowl. Ever.
ChuckW 02-04-2009 10:04 PM
RE: now the cowl!
Can you just push the cowl on a little further?
joco1 02-04-2009 10:30 PM
RE: now the cowl!
no the holes for the cowl are pre drilled with taps inserted
KidVermin 02-04-2009 10:57 PM
RE: now the cowl!
What are you calling too close since you didn't say the spinner rubbed the cowl ? Is the spinner flat back or recessed ?
I try to have the spinner gap between 1/16 to 3/32"
MinnFlyer 02-04-2009 11:13 PM
RE: now the cowl!
Do as ABELL said
joco1 02-04-2009 11:13 PM
RE: now the cowl!
Yes it rubs the cowl its a flat back tru turn spinner.........is there anything i can shim the shaft with or will it be way out of balance and dangerous if i do? i still have a little room on the mounts but i checked again and the measurements are right on where the directions say ...man i hate to take it all apart and redrill those mount holes holes!!!
Gray Beard 02-05-2009 10:56 AM
RE: now the cowl!
No, not really, like able said, you just shim behind the motor mount. I use ply cut just over size to the mount, very easy.
