2.4 mode 1 or mode 2
Hi - see that the 2.4Ghz remotes say either mode one or mode 2. what does this mean?
RE: 2.4 mode 1 or mode 2
Mode 2 is what is typically used in the US, (Elevator and aileron on right stick, throttle and rudder on the left). Not sure what changes with Mode 1.
Curtis |
Its the same as any other transmitter, their are four different modes. Mode 2 is the "common" and most popular here in the US. Throttle and rudder on the left stick, elevator and aileron on the right stick. Here is the explanation for mode 1. http://rcsource.hobbypeople.net/faqs/radmode.htm
Mode One: Throttle/Aileron on the right stick, Elevator/Rudder on the left.
1 Attachment(s)
see diagram
Ken |
Why do people use different modes when mode 2 is the closest to flying the real thing? The ailerons and elevator coupled to the same control lever with the rudder at the feet? I would crash a different mode aircraft in no time, if I could even take off!:D
There's a school of thought that by separating the aileron and elevator you don't accidently cross control while doing precison manuvers.
Lots of europeans fly that way. I couldn't do it but it's all in what you're used to. |
ORIGINAL: brett65 Why do people use different modes when mode 2 is the closest to flying the real thing? The ailerons and elevator coupled to the same control lever with the rudder at the feet? I would crash a different mode aircraft in no time, if I could even take off!:D I fly Mode One! I fly Mode One, because that's the way the guys who taught me to fly, flew. They flew this way because when they transitioned from reed transmitters to digital proportional transmitters (the current type of radio) this was the easiest configuration for them to fly with. Reed transmitters used toggle switches to control the signal sent to the airplane. The toggle switches were spring loaded left/right or up/down center off switches. If the reed transmitter had eight channels, it could have 4 switches, one for Aileron, one for Elevator, one for Rudder and one for Throttle. The switches produced an all or nothing movement at the airplane. Full up, neutral; or, full down, for the elevator. To get a smooth-gentle turn the thumbs had to blip the switches on and off quickly. So, to be able to use the elevator and ailerons simultaneously, the flyer needed be able blip two switches at the same time, use both thumbs to get the job done. Hence the separation of the Aileron and Elevator in Mode One. Being a Mode One flyer, I feel that this mode has much to offer. It has fallen out of favor over the last 30 years here in the US Soon all of the last Mode One flyers will be dead! Then there will only be you Mode Two flyers left. Then, you can all go home to your nice little houses made of Ticky Tacky and you’ll all be just the same! (Thanks Pete!) Seriously; however, the current worlds best R/C Pilot flys Mode One, so it is a viable option! |
I've never seen a full-scale airplane that is controlled by two tiny sticks. :D
ORIGINAL: Mode One ORIGINAL: brett65 Why do people use different modes when mode 2 is the closest to flying the real thing? The ailerons and elevator coupled to the same control lever with the rudder at the feet? I would crash a different mode aircraft in no time, if I could even take off!:D |
ORIGINAL: MikeL I've never seen a full-scale airplane that is controlled by two tiny sticks. :D These are casual observations, of the differences between flying R/C models and real aircraft. Now, when I fire up my G-3.5 RealFlight Simulator, switch to "cockpit view" and fly my airplanes with the little box with the tiny sticks, I find flying them with a Mode One set-up is exactly like flying a real airplane! I will absolutly garrentee you that if you do the same thing with your Ticky Tacky Mode Two flyin' box, it will be just like flyng a real airplane with a Mode Two set-up!! Brett65, sorry, I just had too much fun with this tale; or, is that Tail?!? |
ORIGINAL: brett65 ORIGINAL: Mode One ORIGINAL: brett65 Why do people use different modes when mode 2 is the closest to flying the real thing? The ailerons and elevator coupled to the same control lever with the rudder at the feet? I would crash a different mode aircraft in no time, if I could even take off!:D Also, flying R/C is not like flying real airplanes, it's only like flying R/C. If you think it will be easier for you to learn, using a Mode Two transmitter, I urge you to follow this quest. If you ARE flying with a Mode Two transmitter, please enjoy how much you think it replicates the controls of a real live airplane (your words, not mine). |
Mode 1 = time to build
Mode 2 = time to repair :) |
ORIGINAL: Mode One ORIGINAL: brett65 ORIGINAL: Mode One ORIGINAL: brett65 Why do people use different modes when mode 2 is the closest to flying the real thing? The ailerons and elevator coupled to the same control lever with the rudder at the feet? I would crash a different mode aircraft in no time, if I could even take off!:D Also, flying R/C is not like flying real airplanes, it's only like flying R/C. If you think it will be easier for you to learn, using a Mode Two transmitter, I urge you to follow this quest. If you ARE flying with a Mode Two transmitter, please enjoy how much you think it replicates the controls of a real live airplane (your words, not mine). |
Ok guys, let's back down the conversation a bit. There's no need to get your hackles up over this.
A lot of what determines which mode is used is where you live. In Australia a lot of pilots fly Mode 1, simply because that's what everybody else does. That doesn't make them right and that doesn't make them wrong. It's a lot like the British driving on the other side of the road than we do. It's just the way that they do it. Same thing with radio modes. Ken |
ORIGINAL: RCKen Ok guys, let's back down the conversation a bit. There's no need to get your hackles up over this. A lot of what determines which mode is used is where you live. In Australia a lot of pilots fly Mode 1, simply because that's what everybody else does. That doesn't make them right and that doesn't make them wrong. It's a lot like the British driving on the other side of the road than we do. It's just the way that they do it. Same thing with radio modes. Ken I know when I was in the US it took me ages to learn to drive on the "wrong" side of the road and even walking across the road was flirting with disaster as I kept looking the wrong way for oncoming traffic, yet millions of americans seem to do it with no more than the usual number of accidents. It was a bit of a culture shock the first time I got in the "driver's" side of an american car though, only to find a glove box instead of a steering wheel there. Doesn't matter how often you see it on TV, it's not real till you see it in real life. :D |
No hackles were up for me, I only thought I was explaining my side of the discussion.
Many years ago when I was working at Marshal Space Flight Center there was an extensive study to determine which were the best controls for the Lunar Module. It was set up essentially in mode 1 or mode 2. Everyone participated in trying it in a small simulator, secretaries, engineers, technicians and engineers and finally the astronauts. After many weeks the came to the conclusion that there was no significant difference in ones agility to control. It was just about 50/50 mode 1 vs mode 2 - even with the astronauts.
I think you will find at a number of US mode 1 fliers started with reeds that were set up the same way. Then it became quite obvious if you were going to help others as a test pilot that you had better learn mode 2. It was a painful few months, but most of us made the transition fairly well. |
Then of course, there are us Mode One flyers who never felt a need to change and are comfortable staying with this set-up, as we believe it has benefits that exceed any benefits there might have been from converting to Mode Two. In reality, the only drawback (for me anyway) has been constantly having to explain the story of how Mode One came about, how I came to fly this way and attempt to be tolerant of the people who are absolutly certain that their way is the only right way; or, more like flying real airplanes.
Misread |
ORIGINAL: Red Scholefield Many years ago when I was working at Marshal Space Flight Center there was an extensive study to determine which were the best controls for the Lunar Module. It was set up essentially in mode 1 or mode 2. Everyone participated in trying it in a small simulator, secretaries, engineers, technicians and engineers and finally the astronauts. After many weeks the came to the conclusion that there was no significant difference in ones agility to control. It was just about 50/50 mode 1 vs mode 2 - even with the astronauts. I think you will find at a number of US mode 1 fliers started with reeds that were set up the same way. Then it became quite obvious if you were going to help others as a test pilot that you had better learn mode 2. It was a painful few months, but most of us made the transition fairly well. |
Hi I live in australia and most guys fly mode 1 god knows how they do it been a retired full size pilot most of the planes that i flew for work were stick and rudder now I never flew a pawnee with ail and throttle on the same stick and boy would not fly my models that way either stick to mode 2 the way to go
i'm a Mode 1 flyer as well........learned it from the top pattern flyers back in the late 60's. Phil Kraft spent a whole day at our club and i was fortunate enough to have him teach me quite a bit.
Mode 1 does offer some advantages over the brain/finger thinking though as like someone said, you have Elevator in one hand and the Aileron in the other leaving you some precision in aerobatics, and less confusion for the beginner pilot. the other option to Mode 1 that i like, is that no one bugs you to let them fly your planes:D:D:D |
So from what I read here, mode 1's great for precision and ease of learning, and mode 2's great for people who already fly full scale... fair enough.
ok. So the answer is simple. It's practically the same, just used whatever you feel comfortable with. It's that simple
Per Sandmann AU: So from what I read here, mode 1's great for precision and ease of learning, and mode 2's great for people who already fly full scale... fair enough.
Not really: Radios come set-up Mode Two when purchased, to decide to fly Mode One, the radio will need to go back to the manufacture, in almost all cases to be converted. The cost of doing so is minor; however, before you convert to Mode One make sure there is someone who flys Mode One who can help you! Mode One is no easier to learn then Mode Two. The fact that you fly; or, flew real aircraft has no connection to your choice of flying R/C Mode One; or, Mode Two. There are plenty who have (or had) pilots licenses who fly R/C Mode One, myself included. |
ORIGINAL: Mode One Per Sandmann AU: So from what I read here, mode 1's great for precision and ease of learning, and mode 2's great for people who already fly full scale... fair enough. Not really: Radios come set-up Mode Two when purchased, to decide to fly Mode One, the radio will need to go back to the manufacture, in almost all cases to be converted. The cost of doing so is minor; however, before you convert to Mode One make sure there is someone who flys Mode One who can help you! This was all in response to the "this mode is better than that mode"... which is not always the case. I was just pointing out that both have their strengths, and both can be used equally well, depending on what you've originally learned on (treating full scale 'craft as Mode 2 for the sake of argument). |
Ok, this has gone on long enough. I put out a gentle reminder earlier, yet some want to prove their point no matter what and continue to argue their points. I think that the issues raised by the original post have been addressed, therefore I see no reason to let this bickering to continue. I'm locking this thread.
Thread closed. Ken |
| All times are GMT -8. The time now is 05:24 PM. |
