wing struts
Ihave a 82 inch span trainer type .52 powered .Idesigned my self using a sailplane wing. Do i need spars
RE: wing struts
Only if you don't want the wing to fold
RE: wing struts
Hey Minnflyer that is a vertical landing. (by design) Got in 3 flights this morning. Still kinda cool30*
RE: wing struts
You're thread title says "Struts" but your message says "Spars".
I'm sure that you know that you need a spar to support the wing. I assume your question has to do with struts, like you would see on a Piper Cub, etc.. Most RC planes do not have wing struts unless they are needed for scale realism. BUT, since this plane is an original design, it is kind of up to the designer to decide. Good luck. |
| All times are GMT -8. The time now is 01:46 AM. |
