RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Is this a good engine to use. (https://www.rcuniverse.com/forum/beginners-85/8482199-good-engine-use.html)
flystright 02-16-2009 09:12 AM
1 Attachment(s)
Hi. is this a good engine to use on the Martin AM-1 Mauler size 40-60, Magnum XL 91 RFS 4 Stroke Engine? can buy new for $149.00
Here is the specifications of the plane. Also is the 4C 0.91 size the min or max for this plane. Would like to give this engine a try.
Specifications:
All balsa construction. This model comes with Retract.
Wingspan: 1475mm (58 in)
Length: 1193mm (47 in)
Engine: 2C, 0.61-0.74 / 4C 0.91 size
Radio: 5 channel, 6 servos
w8ye 02-16-2009 09:48 AM
RE: Is this a good engine to use.
It will be just fine
beau0090_99 02-16-2009 09:50 AM
I just posted the same engine to your other thread. I have two magnums (th .46 XLS 2 stroke, and the .52 XL 4S) and I love both of them. The .46 is the only one in a plane so far, but it has a ton of power. People will tell you that they may take a little while to break in, compared to an OS, but the dependability after that is great.
Curtis
flystright 02-16-2009 10:01 AM
Thanks for your help. Will go and re-read post.
