GP Cherokee 40
Hi guys I just got my new Cherokee a few weeks ago, it is my second plane and I almost ready to fly but I was waiting for my pitts muffler to arrive, I ordered it before I found RCken's review and guess what... it was the Q series from slimline... so I was in trouble, according to the review, this muffler was too big so the front wheel could not move... I found that it would not be an issue at low rate but at high rate it is impossible to move the wheel... can I just adjust the rudder with less movement at high rate? It would be too hard to get another muffler and I would have to wait weeks to get it... any advice?
Thanks! |
RE: GP Cherokee 40
I you have a computer radio w/dual rates, you can set the travel where it wouldn't hit. Switch it for flight and taxiing. Make sure that the high rate doesn't effect your rudder movement, and doesn't cause damage if do push it too far.
I would set it at the max amount of travel you can without the wheel making contact and leave it. You won't be doing major rudder manuevers with the cherokee anyway. |
RE: GP Cherokee 40
Let us know how your flight go as I just purchased a used Cherokee with an OS .46LA.
I havent flown a low wing yet... Steve |
RE: GP Cherokee 40
this is my first low wing too... I'm a little concerned about landings as I'm too used to my avistar where hard landings are not big deal...
brett65: do you mean high rates for taxing/take off and low rates for flying? |
RE: GP Cherokee 40
Yes, high for more steering capability, low for flying because you won't be knife edging it.
RE: GP Cherokee 40
the cherokee is a great stable and easy flyer, its basically a low wing trainer(it has the traits) with the ability to do some great intro to aerial tricks!! dont worry, if you can fly your trainer, you will be fine, just take it slow and keep the "dumb thumbs away"! :Dgood lick
RE: GP Cherokee 40
do you guys think that would be a good idea to have someone on the club next to me on the maiden flight just in case? I have been fliying my avistar for two years but I know it would be a little different with the cherokee
RE: GP Cherokee 40
ORIGINAL: L_Vader do you guys think that would be a good idea to have someone on the club next to me on the maiden flight just in case? I have been fliying my avistar for two years but I know it would be a little different with the cherokee I can assure you it's not a bother to whoever you ask! I remember maidening my first tail dragger (heck it was only a few months ago!). There were only two flying buddies at the field (the same two had me solo when the instructors weren't there yet!) and they said 'just fly it!'. I did, and everything went fine. But I was shaking the entire time! I probably still would have shook if Mark or Tony were around, but having them next to me to ask questions, or to tell me to keep the power on until I got closer to the strip or something, would probably have made it a bit more comforting. |
RE: GP Cherokee 40
ORIGINAL: L_Vader do you guys think that would be a good idea to have someone on the club next to me on the maiden flight just in case? I have been fliying my avistar for two years but I know it would be a little different with the cherokee If you have a sim, flip your controller on its back, and upside down, and move the trims away from center. Then, without looking at the controller, take the plane up and trim it out. This will help prepare you for what the plane may do. I myself don't like having someone next to me on a maiden (I never fly alone, I just dont like someone next to me). I do however enjoy the company after the maiden is out of the way. I just dont like the added stress on maiden. |
RE: GP Cherokee 40
well I hope everything goes ok this weekend... I'll try to post some pics of the maiden flight which me good luck :D
RE: GP Cherokee 40
ORIGINAL: L_Vader well I hope everything goes ok this weekend... I'll try to post some pics of the maiden flight which me good luck :D |
RE: GP Cherokee 40
Hello chaps,
I am thinking about getting the GP Cherokee, and as I have seen it has foam wheels. The two flying fields that I fly from (grass and asphalt) are pretty rough for foam wheels so it wont last long, so what size wheels does the Cherokee have? |
RE: GP Cherokee 40
it comes with 2 1/2" wheels
RE: GP Cherokee 40
Hi guys! Well… my Cherokee had her maiden flight yesterday... It was awesome! is very easy to fly but I still need a little practice with landings... for those who just got one of this, I hardly recommend to take the wheel pants off; I made a nice hole on the bottom of the fuselage with the front wheel pant at one of those hard landings. Besides that, everything went just fine!
| All times are GMT -8. The time now is 11:54 PM. |
