engine starts backwards?
started up the trainer last night, and just taxing in the driveway, and it was going backwards, i know for sure the prop was right cause it flew, changed the prop and it went fine... can it start backwards? [sm=spinnyeyes.gif]
RE: engine starts backwards?
yep it can
if it does so throttle down to idle, make a O with your hand and push adginst the spinner till its about to die, let go and it should start turning the right way. or you could just kill it and start it again. if your hand starting it this happens a lot more than w/ a starter |
Absolutely, won't run as well because its timed to run forwards but its quite happy running backwards.
Weird huh. Cox .049s were/are famous for it . Cox engines really don't care which way they turn since the valve is different.
Yes, these engines quite often start backwards. The cause is because the engine is flooded. When you are priming the engine you are getting too much fuel in the cylinder. The cure is to get less fuel in the engine when you are priming it. Here's what I do. With the glow driver OFF of the glow plug open the throttle wide open. Cover the carb mouth, or the end of the muffler if you can't get to the carb, and turn the engine over counterclockwise by hand. You should see fuel being pulled up the fuel tube each time the engine turns over. When the fuel reaches the carb turn it over 2-4 more times. Then close the throttle to idle, put the glow driver on, and start the engine. The amount you turn it after the fuel reaches the carb can be adjusted. If it's still starting backwards reduce the number of turns. If you don't have enough fuel add a turn or two.
Ken |
| All times are GMT -8. The time now is 02:51 AM. |
